Old 11-25-2013, 10:45 PM   #1
groovzilla's Avatar
1966 20' Globetrotter
Seattle , Washington
How to remove window hardware 1968 overlander?
all,
2 of my curved windows are plexiglas and i will be replacing them with new curved glass - i need to remove the channel/hinge that holds the glass so i can work on removing the tons of glue that prevents me from removing the last bit of plexiglas in the channel.
can someone please explain or point me in the direction of a post with photos please?
thanks in advance
groovzilla is offline   Reply With Quote
Old 01-13-2014, 02:19 PM   #2
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Did you ever figure out what do about your windows?
desertair27 is offline   Reply With Quote
Old 01-13-2014, 04:24 PM   #3
DFlores's Avatar
1968 22' Safari
Where are you exactly? Have you removed the windows from the trailer?....or are you at the point of removing the glass from the hinge on the bench?
DFlores
David & Diana
DFlores is offline   Reply With Quote
Old 01-13-2014, 05:13 PM   #4
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
I have one window still in place with plexi and I found a nice used window with upper hinge attached as pictured in previous picture. I was hoping to remove complete plexi and hinge and replace with this one.
Old 01-14-2014, 08:06 AM   #5
groovzilla's Avatar
yes i removed the plexi glass window from the hinged hardware and replaced it with new curved glass. i posted a thread on removal which was difficult because of all the glue that was used when previous owner installed plexi glass
Old 01-14-2014, 08:55 AM   #6
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Groovzilla has a really good thread in the Overlander 1968 tab dated 11/26/13 titled 68 Overlander window removal. Lots of photos.
Dan
Old 01-15-2014, 01:08 AM   #7
groovzilla's Avatar
thanks!
'58 Hehr Window - Is this the correct window operator replacement? mello mike Windows & Screens 22 10-08-2012 08:49 AM
Help replacing window panes MAbdala Windows & Screens 3 01-22-2012 02:22 PM
AS280 - Front (driver) sliding window latch dalefox Classic Motorhomes 13 01-05-2012 06:41 PM
1968 Airstream Overlander - Beautiful Interior - Recently Restored! eBay Watch Airstreams on eBay 0 09-18-2011 03:10 PM
Shattered window in '98 Airstream- advice needed NoMoSOBs Windows & Screens 18 07-29-2011 01:14 PM
