Old 02-15-2016, 04:36 PM   #1
1966 26' Overlander
los alamos , California
How to remove the lower small window glass
Hi there,
I have recently started my first renovation on a 1966 Overlander Twin and am a bit stuck on how to remove the glass from the lower window to the left of the door. I want to replace the seal and clean off the old film.
Any help from you experienced lot out there would be most appreciated.
Jason
evey1966 is offline   Reply With Quote
Old 02-15-2016, 04:48 PM   #2
newas4mark's Avatar
1968 30' Sovereign
Rockford , Michigan
I would guess that your 1966 is similar to my 1968. My stationary windows are held in by a rubber insert on the inside of the glass. There is a caulk or butyl of some sort between the glass and the channel they are in. You must remove the rubber inside strip, then try to free the glass from the bedding. The rubber insert is available from Vintage Trailer Supply. Good luck! If the glass breaks, you do not have to use tempered for the replacement.
newas4mark is offline   Reply With Quote
Old 02-16-2016, 12:33 PM   #3
Hittenstiehl's Avatar
1961 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
If its like ours it will fall out.
Actually as stated already.
Pull out any rubber, seals gaskets, tubing and gently go at it with a small putty knife, acetone etc.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
credenza, dining table, small table for top of credenza, small table from other side of trailer janeinthemtns Airstream Classifieds 1 09-25-2014 05:24 PM
How do you remove frame around fixed Vista window glass? montanablue Windows & Screens 0 06-28-2011 09:00 AM
'68 Overlander Small lower window Pete66GMC Windows & Screens 3 10-13-2010 08:59 AM
replacing windows - glass, lexan, tempered glass? BrianY Windows & Screens 4 07-01-2010 12:08 PM
'68 Trade Wind Small Lower Window Removal 68 TWind Windows & Screens 6 08-21-2009 08:34 PM
