Old 06-16-2002, 01:24 AM   #1
Administrator
Andy R's Avatar
1961 16' Bambi
Dallas , Texas
Images: 13
Question How tor emove the glass from windows?
I need to remove the glass from the window frames so I can clean & restore the frame. I will then use new weather stripping.
The current stripping is very hard.
Would it be easiest to break the glass out?
I am hoping someone has a trick so I won't have to do that!
AIR # 2 - 1961 Bambi - Jeep Cherokee
Campground Reviews: Submit and review campgrounds around the US
Andy R is offline   Reply With Quote
Old 06-18-2002, 04:37 PM   #2
Administrator
Andy R's Avatar
1961 16' Bambi
Dallas , Texas
Images: 13
Got the weather stripping off...
I used a 1.5" scraper with a fine flat edge to slip in between the weather stripping the frame, the I lightly separated the stripping from the frame. I started on each corner. Once the stripping was 2" pull off, I was able to pull on it and get the rest to come off pretty easy.
Now the glass is stuck to the old inside window liner. I am afraid it will break when I try and dis-lodge it. Any Tips?
Old 06-19-2002, 09:30 AM   #3
Andy. Breaking the glass is the best way. If you try to remove the glass, you will most likely break it, needless to say, wasting the time as well.
We replace the older windows with the AR-2. It's not cheap, but it works great and doesn't scratch, but it can break. Lexan is the toughest material, is not cheap, but it scratches easily.
Decisions, decisions.
Wondering what kind of glass to use for replacing all windows in 1958 Traveller williamhenshall Windows & Screens 3 08-19-2007 07:15 PM
Open your frameless windows wide? TomW Windows & Screens 17 08-23-2004 08:14 PM
Glass windows; insulation smallfry Windows & Screens 5 01-10-2003 05:15 PM
What type of glass should be used on a 60s AS windows? Andy R Windows & Screens 1 06-19-2002 09:23 AM
