Old 04-09-2010, 05:27 PM   #1
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
How to get to the...
Ok here's another problem I have not figured out. On the front door side near the hitch front --up above is the vista view window. And it's ok and everything, but when the plastic type slide that opens and shuts is pulled down, you can see staining and cleaning to be done. So I stood inside and slide it up and down...up and down...wondering how does one access to the other side of it to clean it? Or do you have to take a major part (wall) out to achieve this???
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 04-09-2010, 09:42 PM   #2
funkill's Avatar
reno , NV
Images: 27
Yes.
Laura
funkill is offline   Reply With Quote
Old 04-09-2010, 09:43 PM   #3
funkill's Avatar
reno , NV
Images: 27
Actually, I saw a post on this previously and it mentioned removing a portion of the adjacent panel -- the bottom side only. Search on "vista view" repair and you should be able to find it amongst the list!
Laura
