Old 01-06-2016, 12:22 PM   #1
1977 23' Safari
Carberry , Manitoba
How to fix window gasket?
How does one fix this? My 1977 Airstream, Safari, land yacht has several windows like this. Will the VTR 1970 Airstream Window glazing Strip VTS-477 fit? From my searches I am thinking this is the right one? any confirmation?
TIA - Lorry
http://www.airforums.com/attachments.../8/photo_2.jpg
cp1977 is offline   Reply With Quote
Old 01-10-2016, 11:34 PM   #2
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria , British Columbia
Not positive about your model year but I used that 1970's U-Channel glazing strip from Vintage Trailer Supply successfully on my 1969 Safari. It looks the same as your pic but to be safe maybe order a foot to compare it to what is exposed in yours.
thesignlady is offline   Reply With Quote
Old 01-11-2016, 09:28 AM   #3
youngpeck's Avatar
1976 25' Caravanner
Salt Lake City , Utah
In order to replace the gasket you will need to remove the window and take it apart. There is a gasket that will fit this particular window--I bought a carton of it for my '76 Caravanner and rebuilt eight windows with it. The stuff that VTS sells is too narrow for an exact rebuild of the double-paned windows. Mine is from the same supplier from which VTS must obtain the "-477" gasket--it is just wider, 1/2 inch to be exact. But it worked quite well for what I did.
If you just want to fix that portion of the gasket (without taking the window out and rebuilding it) that has separated and shrunk, as you show in your picture, then I would do what many others on this forum whose advice I respect and endorse, and cut out the offending portions of gasket and apply either trempro or sikaflex. If done correctly it will look and work fine. A lot less work.
I had to rebuild my windows anyway--the gaskets were really bad, and the film on the interior of the glass panes was bubbling and peeling.
If you decide you need the gasket that I have, let me know. I can sell you some--I had to buy a case, which was about three times more than I needed. I also have a lot of butyl tape, which I used to pack and space between the two panes of glass.
And, I also have a slightly wider gasket that fits the Vista View windows.
youngpeck is offline   Reply With Quote
Old 01-11-2016, 09:33 AM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
"D" gasket for Inland RV, if I remember right.
Old 01-11-2016, 10:55 AM   #5
Tom T
Tom_T's Avatar
Orange , California
TIA - Lorry
Larry, have you tried asking them at VTS about it?
They're usually pretty good about that sort of fitment info., & they can also send you a short snippet of it to compare for yourself (they did for me to try another type for my `60 Avion T20).
Good Luck!
Tom
Tom T (janabanana48's other half )
Orange CA
1960 Avion T20, #2 made, Hensley Cub, TV tbd- looking for 08-14 Cayenne S
1988 VW Vanagon Westfalia CamperGL (Orig Owner) + 1970 Eriba Puck
Tom_T is offline   Reply With Quote
Old 01-11-2016, 12:07 PM   #6
1971 27' Overlander
Jackson , Tennessee
This is the route I took, and I am very pleased with the result.
Alan
TennTex is offline   Reply With Quote
Old 01-12-2016, 08:15 AM   #7
1977 23' Safari
Carberry , Manitoba
Thanks everyone for taking the time to help, I think I will do a test on one window using the cut and caulk method. See how it turns out and then decide if I am up for full on replacement or not. (I have lots to do, have just started stripping the exterior in prep for polishing)
Lorry
Old 02-05-2016, 08:48 AM   #8
Tap
Newbie -- 1981 280 MoHo
Tap's Avatar
1981 28' Airstream 280
Minneapolis/St. Paul , Minnesota
This is great information.
Thanks guys!
"The Aluminum Falcon"
1981 Airstream 280 (28') Motorhome
Tap is offline   Reply With Quote
Old 02-11-2016, 05:46 AM   #9
1983 27' Excella
French Settlement , Louisiana
window leak
I have this type gasket also worse than yours, will this cause a leak, the drip cap looks good and the gasket is pulled in top right corner near the leak . Or do you think it is the weather-strip . I will fix it by calk and see
housebg is offline   Reply With Quote
Old 04-05-2016, 08:25 PM   #10
1976 31' Sovereign
ft myers , Florida
Can you tell me where you bought the gasket for the double pane Windows? 477? I need it or a gasket to go from a double pane to a single pane window. Jack
Lyrekjack is offline   Reply With Quote
Old 04-05-2016, 09:40 PM   #11
youngpeck's Avatar
1976 25' Caravanner
I have some of it--actually quite a bit of it for the double-paned. I had to buy it in a very large quantity. Please send me a private message if you are interested in some. We'll need to determine that it is exactly what you need.
Old 04-07-2016, 07:01 PM   #12
1976 31' Sovereign
ft myers , Florida
I was going to go to a single pane glass as I have heard that so many of the double pane Windows fog up again. How are yours ? Have any of your failed ? How long has it been since you restored them. I sure do need a solution. Thx Jack
Old 04-07-2016, 09:46 PM   #13
youngpeck's Avatar
1976 25' Caravanner
I rebuilt thirteen of my windows, all double-pane, last summer. Turns out the very first one I did failed this winter and has condensation inside. I'm assuming I learned something along the way since all the others are just fine. So I will redo the first one in a week or so. I most likely didn't get a good seal between panes. I used butyl tape between the panes and it's possible I was sloppy on the first one I did. I'm confident I will get it right this time. If any of the others were bad I'd know it by now.
Don't fret! If I can do it anyone can. The important thing is to keep everything clean and pay attention to measuring correctly. All of mine had failed tinting one the inside. They look brand new now.
Old 04-07-2016, 11:50 PM   #14
1976 31' Sovereign
ft myers , Florida
I am going to look for away to put a single glass panel but if cannot work it out I will cell you. Ron 612-282 3971. Z
To fix or not to fix nayl Ribs, Skins & Rivets 16 07-17-2010 08:38 PM
You Fix-You Camp-You Fix Some More juel Off Topic Forum 6 08-18-2005 07:50 AM
Window Gasket/Seal - Help! Herm and Debby Windows & Screens 13 07-21-2003 01:54 PM
window gasket replacement JayClay Windows & Screens 3 05-05-2003 09:35 AM
Source for window gasket jaiman Windows & Screens 2 09-07-2002 09:16 PM
