Old 05-14-2016, 12:31 PM   #1
GaŽl's Avatar
1960 26' Overlander
In the North , FRANCE
Images: 8
How to fix a glass window on the frame ?
Hello,
I have a doubt...
The glass window is glued on the frame ? or only the external gasket maintains the glass window ?
Thank you for your answer
1960 Overlander
2002 Chevrolet Tahoe
GaŽl is offline   Reply With Quote
Old 05-15-2016, 12:20 AM   #2
GaŽl's Avatar
1960 26' Overlander
Images: 8
I found my answer, I need Butyl Tape and then the exterior gasket maintins the glass windows
1960 Overlander
Old 05-21-2016, 04:21 PM   #3
1968 22' Safari
Tulsa , Oklahoma
May I steal this thread?
Gael, it seems you've self-discovered your answer. Mind if I hijack this thread?
We're in the process of refurbishing the windows on our 1968 Safari. The spousal unit seems to have a grip on the FUNCTIONAL WINDOWS, the curved ones that open and close, and this question does not relate to those. THIS RELATES TO THE FLAT, FIXED PANES THAT ARE BELOW THE WINDOWS THAT OPEN AND CLOSE.
These appear to rest against a 360 gasket installed on the interior side of the window frame ("the first gasket") and seem to be held in place with another 360 interior gasket ("the second gasket") that is installed on the interior side of the glass after it's placed onto the first gasket. Vintage Airstream recommended, and we purchased, three things for the project: a second gasket that looked like the first pic below. They also supplied a bulb gasket (2nd pic) and some butyl tape.
When I pulled out the first pane, I found the old gasket on the exterior side (the first gasket) to be a simple piece of flat rubber, badly decomposed, third pic below. Is this supposed to be replaced by the bulb gasket? If so, I don't think there's enough room. I mean, if I glue the bulb gasket to the window frame and put the glass on top of it, I don't think there'll be enough room to insert the second gasket into the groove to hold the glass in place - and seal out moisture. Or, does the butyl tape go onto the frame as the "first gasket"? That would not only seal it, it would do a pretty fair job of holding the glass in place.
I'm mindful of the community's criticism of bulb-type gaskets.
Confusing...
Jay & Lisa
ID:	262923   Click image for larger version
Name:	OldOutside Gasket.jpg
splyb is offline   Reply With Quote
40" Curved Glass Window and Frame Wanted Customs Airstream Classifieds 0 02-13-2014 03:16 PM
1972 31' Sovereign Window Frame and Glass kjterz Airstream Classifieds 0 09-24-2013 05:39 AM
How do you remove frame around fixed Vista window glass? montanablue Windows & Screens 0 06-28-2011 10:00 AM
2007 Classic front center window glass/frame interference dznf0g 2006 - 2010 Classic (all lengths) 0 03-23-2011 10:44 AM
Glass to window frame sealant crispyboy Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 04-21-2007 11:33 AM
