| Removing old clips from windows
Ingrid, First find your WD-40 and spray the clips that are rusted on the old glass. Let it soak in about 15 minutes and gently push down with a flat blade screwdriver to loosen the clips on the glass. Once off the edge of the glass then slide a wire coat hanger into the gap between the bottom of the clip and the glass. Put enough hanger through so you can bend it into a finger loop on both ends with 3" of hanger hanging down on both sides of the clip and pull down with two fingers until the clip releases from the window. Voila' you have remove # 1 then on to the next. Unbend one end and repeat the previous steps. Clean the windows with ammonia and then windex and install new clips w/adhesive. Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT FORUMS MEMBER SINCE 12/16/2004 AIR#7110 "My tire was thumping, I thought it was flat! When I looked at the tire... I noticed your CAT!" Burma Shave |
