Old 04-05-2017, 04:43 PM   #1
2001 30' Excella
Full-time traveling , Hmmmm. what day of the week is it?
How do you get curtains off the railing?
We have a 2001 30' Excel with white curtains that need to be dry cleaned.
We cannot figure out how to get them off the railing (see photo)
Any advice?
2001 Excella 30' (Beauty)
2014 Ram 2500 Diesel 4x4 (The Beast)
http://www.LivingInBeauty.net
JBBeaubeaux is offline   Reply With Quote
Old 04-05-2017, 05:07 PM   #2
Hiwheel Joe's Avatar
1984 27' Sovereign
Oklahoma City , Oklahoma
The end of the rail may have a plastic clip that has either a screw or robot in it. Remove the clip and the plastic curtain guides should slide out. Some rail may just have a screw or something in absence of a clip.
Hiwheel Joe is offline   Reply With Quote
Old 04-05-2017, 05:08 PM   #3
1984 27' Sovereign
Rivet not robot. Auto correct��
Old 04-05-2017, 06:03 PM   #4
2001 30' Excella
Originally Posted by Hiwheel Joe View Post
The end of the rail may have a plastic clip that has either a screw or rivet in it. Remove the clip and the plastic curtain guides should slide out. Some rail may just have a screw or something in absence of a clip.
I was sure hoping for an easier way.
Old 04-05-2017, 07:54 PM   #5
DaveMc's Avatar
2005 30' Safari
Montgomery , Texas
Ours had a small screw at the end of the track... 2 screws removed and they slide out the end. You don't have to remove the whole track.
DaveMc is offline   Reply With Quote
Old 04-05-2017, 08:53 PM   #6
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Very easy, one screw top and bottom.
MICHAEL
Old 04-06-2017, 12:17 PM   #7
dcasr's Avatar
1990 29' Excella
Stone Mountain , Georgia
Any advice?
____________________
But wait! before you take the curtains down find a way to mark each curtain as to where it came from in the AS and how that curtain should be oriented, up/down left/right. I didn't and misinstalled mine several times before we got it right. I thought it would be obvious. It wasn't when they were all nice and clean.
We washed our curtains ourselves by gently soaking them in soap and working the soapy water gently through them by hand, hand rinsing them, rinsing them again, and then squeezing them and letting them air dry. No shrinkage and all stains came out. Only problem was incorrectly reinstalling them. Good luck.
WBCCI 2456 Georgia Unit 32
1990 Excella 29' Centramatics
2016 GMC Sierra Crew Cab 2500 HD 4x4
6.6L Duramax + Allison, 3.73 axles
dcasr is offline   Reply With Quote
Old 04-06-2017, 12:37 PM   #8
1978 Argosy Minuet 6.7 Metre
1971 27' Overlander
1973 31' Sovereign
Griffin , Georgia
Images: 14
I have renovated several old airstreams I always wash the drapes in my machine with a little soap and bleach. Then I hang them out to dry. They can be reinstalled immediately after drying. they've turned out beautifully.
paddle whisp is offline   Reply With Quote
Old 04-06-2017, 12:38 PM   #9
Skamokawa , Washington
Argosy minuet 6.7 1978...I had to remove a shelf and unscrew one end. My rails must of been put in before cabinets. �� Quick job turned into all day. Ahh, the streaming way!
sherry23bee is offline   Reply With Quote
Old 04-06-2017, 03:30 PM   #10
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Oh, dang! I was about to run out to the Bambi and look for the robots holding the curtains in!
TB & Greg and Abbey Schnauzer
#3954
Old 04-07-2017, 09:36 AM   #11
banderabob's Avatar
2008 19' Bambi
2012 23' Flying Cloud
Bandera , Texas
Plastics end cap snaps off & on, easy peasy.
banderabob is offline   Reply With Quote
Old 08-01-2017, 07:24 PM   #12
White Bear Lake , Minnesota
Spell check is my worst enema.
lyleapgmc is offline   Reply With Quote
Old 06-01-2019, 01:31 PM   #13
2015 30' International
FREDERICK , Maryland
Ours had 1 screw on each plastic end cap either top or bottom. You just need a short stubby Phillips head screwdriver
Doc Foster is offline   Reply With Quote
Awning Railing russellsue Airstream Classifieds 0 04-02-2015 11:51 AM
A Dumb Question: How to remove curtain snaps on railing?. Dickandvicki Upholstery, Blinds, Walls & Interior Finishes 16 09-09-2013 02:49 PM
How do you get curtains off the rack? Jo Mojo Upholstery, Blinds, Walls & Interior Finishes 7 10-30-2010 10:18 AM
Railing for Rope and Pole Awning? oldtrucksrul Awnings 5 06-06-2009 06:41 AM
Curved WindowCurtain Railing Attachment winner Upholstery, Blinds, Walls & Interior Finishes 4 11-01-2002 09:14 AM
