01-20-2015, 10:46 AM
1975 Argosy 26
Horseshoe
How do these windows open?
This is probably a stupid question but we are new to Airstreams. We have a 75 Argosy and we can't open the windows without having to push them open from the inside. The bars that attach to the windows and the plastic channel that locks them open in 3 positions are both still there and attached. I just don't know how to open them once we replace the screens. I checked the forum and didn't find another thread on this topic but I apologize if I over looked one. Thanks for all of your help.
01-20-2015, 04:48 PM
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio
You just lift up on the bars to open the window and then place the bars in the channel. I say "just"-sometimes this can be difficult to do so I usually have my wife help from the outside.
PS-make sure the locks are released.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
01-20-2015, 04:51 PM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
The gaskets have been known to stick, so an old credit card can be slid between the window glass and the gasket to allow the window to open.
Use a dry silicone to lube the gaskets after the windows and door are open.
01-20-2015, 05:36 PM
1974 Argosy 26
Morrill
, Nebraska
Unlock the window at the bottom. Lift while pushing the side bars out. There is a knack to it.
Once unlocked. Gently pry the window from the outside to free it up from the stuck gasket.
It is possible, once the window is free. Just to lift it up from the outside.
Sent from my iPod touch using Airstream Forums
01-20-2015, 05:41 PM
2005 30' Classic
Burlington
I imagine these windows are different than the style on our 2005 Classic, but I also have trouble opening ours sometimes because of infrequent use and the rubber gaskets sticking to the windows.
I found I could pry them open from outside to break them free from the gaskets but I was concerned that sooner or later I would break a window doing this.
So what works better for me is a large (6" dam?) suction cup on the glass from the outside.
The suction cup has a vacuum release valve on it so it is easy to remove once I pull the window open.
Brian.
PS - I was able to use the same suction cup to successfully pull out a dent the the previous owner had made on an end cap up on the roof, presumably from stepping on kneeling on it. Worked very well!
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
01-20-2015, 05:49 PM
2007 28' International CCD
Springfield
I use a Teflon spray from Lowes on the gaskets every year.No more stuck windows
01-20-2015, 07:42 PM
1974 Argosy 26
Morrill
, Nebraska
Unlike the windows on today's A$'s. The '75 Argosy has a metal frame around the window.
01-21-2015, 10:30 AM
1975 Argosy 26
Horseshoe
Thanks guys! I can open them fine with help from the outside. I just thought we were doing something wrong since it took two of us to open the windows. These windows are heavy though, especially the big front one. I guess it will take us a while to learn all these little things.
01-21-2015, 11:47 AM
Regular Guy
1978 31' Sovereign
Hot Springs
, Arkansas
If you have the lift arms, which would be on each side of the window, you have to push them in the direction of each other (toward the center), and as you are doing that, push downward to open the window. If yours operates like my 78 Sovereign, there should be three positions open. Im thinking that since you had help from the outside, that was enough to release the catch as you pushed down. Maybe.
There is no such thing as a stupid question here. You may see some goofy answers though.
Have fun with your new Argosy, and welcome to the forum!
01-21-2015, 12:41 PM
2004 30' Classic Slideout
Fenton
The key is getting lube on that gasket. I typically spray some silicone on a paper towel and then wipe the gasket after you get the window open. Do it enough and you will eventually see those windows open fairly easily.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
01-21-2015, 03:21 PM
Alamo Heights
The ones you're describing didn't come on Argosy trailers, I don't think. I've seen them on Airstreams of certain years but the Argosy ones all seem to have the simpler metal rods you push upwards to lift the windows and those don't give you much leverage when the gaskets are sticky.
— David
02-22-2015, 11:18 AM
TetonStreamer
2021 27' Flying Cloud
Delaplane
Sticky Windows
I just saw an ad in Airstream Life for a "sticky window release" device. It looked like a Teflon screw installed in the inside bottom of the window. (Maybe one screws it in to break the seal?) Anyone have any experience with this item?
Teton Streamer - in The Toaster
Wilson, WY 83014
02-23-2015, 12:05 PM
2014 31' Classic
Apache Junction
Pushing on a single "spot" on piece of glass with that plastic/nylon screw can generate many smaller pieces of glass. Running an expired edit card between the gasket and glass places no stress on the glass. After lubing the gasket with dry silicone, the windows will not stick for quite awhile.
02-23-2015, 12:07 PM
2020 28' Flying Cloud
Upper St Clair
, Pennsylvania
Credit Card slide and silicone from a tube, lightly applied to the gasket. They open easy after that.
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
02-26-2015, 11:00 AM
Tucson
We have similar sticky windows in our 345 MH..... a number of windows are stuck and not opening.... Does the Credit card and silicone work on this models as well ?
02-27-2015, 07:22 AM
2014 31' Classic
Apache Junction
I think this trick works well on the glass windows that push directly out (hinged at the top) from the bottom. The 1991 345 motorhome I saw last week had slider windows in tracks. Not sure this method could work, but one can try.
