Old 05-13-2007, 07:14 PM   #15
till's Avatar
Lisle , Illinois
Images: 108
Donna/Mike,
Is Dow Corning RTV-732 the same stuff your talking about?? If so that is what is call out in the maintenance guide. It would be cool if it is the same.
Tedd Ill
AIR#3788 TAC IL-10
1967/8 Overlander International Twin w/ bunk/s.
Yes, four kids and two adults in the thing.
Happy wife, happy life.
till is offline   Reply With Quote
Old 05-13-2007, 09:19 PM   #16
flitzwhopper's Avatar
1976 Argosy 24
Tempe , Arizona
Sometimes Permatex 66b sometimes Devcon products and sometimes Dow Corning products. I go to my specialty mechanics and they give me the prescription. I am inclined to find the most permanent and rigid solution. They recommend something that does the job but isn't overkill. I was going to epoxy the windows in my car and my advisors reminded me that I might want to replace it someday. Hence the RTV. It sounds like a medium performance RTV like a Permatex 66b would be adequate. However, I havent seen it in large tubes.
Hope this helps.
Donna & Mike
Cowboy up! or go sit in the truck
Charter Member Four Corners Unit
WBCCI #2417
flitzwhopper is offline   Reply With Quote
Old 05-14-2007, 01:40 PM   #17
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Talking
Since my wife doesn't take part in the forums, I guess I can tell where I found a source for a plastic inner surround for the AS window. This morning, I bicycled up to the hardware store and searched in vein for anything. Even went through their supplier catalogs and found zilch.
So I rode back home and decided to work on something else, namely, our newly repaired bulletin board cover, which I'd stored for the winter in Maria's storage room. Went in there to fetch it -- and noticed a thing she'd bought to mount posters. It's a big piece of cardboard with a thin plexiglass cover, and with nice, plastic surrounds to hold the whole business together. Ah! So I pulled off one of the surrounds, snuck it past my wife to the garage, and measured it with the calipers: Exactly 1/8th inch.
Lynn
WBCCI 21043
Old 05-21-2007, 02:10 PM   #18
Originally Posted by eubank
Ok, that's the story. Please let me know your ideas!!
Lynn
PS: This is only the first of the problems we had with the Airstream on this trip! I'll explain others in separate posts.
Lynn.
1966 windows are held in place with "silicone sealer."
1967 and 1968 windows are held in place with "double sided" tape.
Old 05-21-2007, 07:35 PM   #19
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Lynn.
Double sided tape? Boy, I hope that is strong stuff, because the new glass windows that the folks at Vintage are supplying are heavy things!
Lynnnnnnnnnnnn
WBCCI 21043
Old 05-21-2007, 08:21 PM   #20
5 rivets, 1 loose screw
Rog0525's Avatar
1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
I absolutely would not use double sided tape for the heavier glass. I think Andy was just posting info on the originals, but I'll let him speak for himself if he sees fit. One very important thing on replacing these windows is to clean out the groove where the top of the window pane fits as much as possible. Leaving old glue or tape residue will not allow the new window panes to seat snugly.
Rog
May you camp where wind won’t hit you, where snakes won’t bite and bears won’t git you.
Rog0525 is offline   Reply With Quote
Old 05-22-2007, 08:03 AM   #21
1976 Argosy 24
Tempe , Arizona
Rtv
JUst wondering.... Nobody likes RTV for window installs? It seems to like to stick to aluminum and glass. If someone knows why it is not a good idea, I would like to know. Really, I won't be bent if I'm wrong about this.
Donna & Mike
WBCCI #2417
Old 05-22-2007, 04:40 PM   #22
Rog0525's Avatar
Images: 11
According to the installation tips on VTS:
“In all cases, the glass is held in place using a sealant or adhesive bedding tape in the groove of the glass bar. The original sealant used was Dow Silastic RTV-732. It is still available, although other sealants may work as well or better than the original.”
I used 3M silicon weatherstrip adhesive simply because it was available from my local hardware and it seems to be doing a fine job so far.
Also on the VTS site:
“Most of our customers simply use silicone RTV sealant instead of tape.”
Rog
Old 05-22-2007, 05:30 PM   #23
We have used the 1/16" double sided tape for years. NO FAILURES.
As with anything, use the proper materials. Proper materials are not to be found at K-Mart, as all to many owners find out the hard way.
There is industial (very good) double side tape to hardware store junk that is available.
Old 05-22-2007, 05:54 PM   #24
Rog0525's Avatar
Images: 11
Andy, I’m not questioning your judgement on proper replacement procedure for the original windows. The question on this thread is about the heavier and thicker replacement windows from VTS falling out possibly due to hot temps. My personal opinion is that the windows fell out because a tar-based adhesive was used rather than the recommended silicon adhesives. If you are saying that double-sided 1/16” thick industrial tape is ok to use on the non-original 1/8” thick VTS windows, I bow to your expertise.
Rog
Old 05-23-2007, 04:19 PM   #25
Our replacement windows are heavier too.
The double sided tape is the best for the 67 and 68 models.
Unfortunately, silicone sealer is the only (and original) option, for the 66 models.
Mounting a 66-67-68 window in the hinge with a tar based anything, is a joke.
Of course it softens with heat, and then what?? The glass will fall out, but of course!!!
Unfortunately, you found out the hard way.
Some newcomers to Airstreaming have great ideas about how to, etc., that can be misleading sometimes.
The proof in the pudding, is always the long haul performance.
Window latch dilemma maxandgeorgia Windows & Screens 5 05-18-2018 10:35 AM
Oval Window Frame Replacement MikeMikeMI Windows & Screens 8 12-30-2007 10:49 AM
1974 Excella front window docu post john hd 1973-1974 Excella 500 22 08-06-2004 01:53 PM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 06:04 PM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 12:40 PM
