Old 02-16-2016, 06:37 AM   #1
Portland , Oregon
Herh Standard Hinge Repair
I have an early 1950's Hehr Standard Window. Click image for larger version
Sometime In its sordid past an object hit the lower window hinge, crush inning a small portion of it.
Also in the last picture you will see a hinge portion from another salvaged window. It was broken in half and only the above was useable
Can I graft the good hinge portion to the older frame?
I know aluminum is not responsive to major metal movement, no memory like steel.
Other than plexi, gaskets and screen, it seems useable.
bikeukeguy is offline   Reply With Quote
Old 02-16-2016, 07:38 AM   #2
Central , Mississippi
Graft away. The large front window has the hinge in pieces so it will work on a small one.
I've actually made some of those hinges but they are a total pain to get to work.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Herh stadard window hinge info desertair27 Windows & Screens 1 03-31-2013 08:50 PM
Standard or Non-Standard Roof Vent and Skylight man7sell Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 03-27-2011 08:41 PM
Why did Airstream change from front hinge doors to suicide hinge doors? arcamedies Airstream History 28 08-20-2010 11:39 AM
Standard Conscious on Window Repair timatron Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 07-13-2010 11:17 PM
HERH Operator Screw Trailer Girl Roof Vents, Skylights & Fans 11 06-09-2005 07:33 PM
