Old 04-22-2010, 11:19 AM   #1
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
Help With Window Parts
I am looking for the plastic parts that hold the windows open on a 1971 Overlander. Most of them are broken on my trailer. I can try to get a picture. Also, I have a question on the sliding panel over the upper window. Can you get a new one of these? It is all broken up under the panel and it is hard to close.
Mel
2006 GMC 1500 SLE Crew Cab
5.3L V8 Towing Package
Equal-i-zer E2
AIR # 40365
TAC # OK-3
mwells4654 is offline   Reply With Quote
Old 04-22-2010, 11:21 AM   #2
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
Next, This is from the kitchen window - the PO broke the blind holder so they stuck a pen end to hold it up. What is the best way to repair this?
Mel
Equal-i-zer E2
AIR # 40365
TAC # OK-3
Old 04-22-2010, 08:55 PM   #3
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Here are the window lift brackets. I bought mine from Airstream at the factory and recall them being like $6.50 each. I can buy rivets anywhere. When you install them the rivet holes don't quite line up so I did top and bottom then drilled the other two.
You need to remove the interior handles and pull the rod outside to thread it through the bracket - you'll see what I mean when you do the first one.
3 Position Window Kit SKU:8284KIT - $16.38 : ODMRV , Out-of-Doors Mart
Old 04-23-2010, 04:24 AM   #4
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Take a look at this window trim on Ebay. It may be too large but worth measuring. You could fiberglass the back where it has minor cracks....
1972 airstream interior rear window trim : eBay Motors (item 180495272146 end time Apr-24-10 05:11:55 PDT)
Old 04-23-2010, 04:29 AM   #5
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
If your looking for the plastic trim/slide around the window that the panel fits into - the only way your going to find it is to keep looking for a trailer that's being parted out. If you watch Ebay and Search Tempest (craig's list helper) they show up a few times each year....
Old 04-23-2010, 06:48 AM   #6
Birdwell57's Avatar
1978 31' Sovereign
Madison , Mississippi
Try this site
Aircraft Plastic Repair
Birdwell57 is offline   Reply With Quote
Old 04-23-2010, 06:58 AM   #7
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Inland RV and maybe Vintage Trailer Supply sell the guides. The inside trim is brittle and new is not available. Any replacement vintage interior trim will also be brittle. You may be able to put a fiberglass patch but no way to fix the brittleness
Old 04-23-2010, 07:10 AM   #8
That part is called "window position guide".
The vista view plastic shades are obsolete.
Old 04-23-2010, 07:51 AM   #9
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
mwells4654 I have the trim piece for around the kitchen window off a 1975 Tradewind you can have the the sum of nothing plus shipping.
Bruce
bmklawt is offline   Reply With Quote
Old 04-23-2010, 08:53 AM   #10
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Originally Posted by Birdwell57 View Post
Useful site - thanks for posting....
'66 GT window parts needed CtRobert Windows & Screens 1 04-22-2010 11:10 AM
Carefree window awning parts WineStream Windows & Screens 0 03-06-2009 06:47 PM
'56 Bubble missing window parts Dan G Windows & Screens 3 01-23-2009 01:32 AM
Help w/ window parts needed! Auretrvr Classic Motorhomes 9 11-03-2006 06:43 PM
Window Parts Over59 Windows & Screens 3 06-30-2004 11:10 AM
