Old 11-22-2011, 08:13 PM   #1
MrJ
MrJ's Avatar
1976 28' Argosy 28
Dallas , Texas
Help - Window Leaks - '76 Argosy
I have a 76 Argosy MH. It rained hard last night and I have some leaks. I traced the leak to under the window in the exact center. I just replaced the schelegle and outside trim. I don't understand where the water could be coming from. (This happened before I did anything to the window)
With this window design can water come in from the top and wrap around to the bottom middle? Could it be the post in the middle holding the glass. Rivet is in there. I do have some issues with calk at the top of the window cracking. Could this be it? I don't feel water on the sides of the window or the bottom corners.
I think I have 3-4 windows like this. There is a crack in the Vlukem seal due to age and vibration.
thanks
ID:	145822   Click image for larger version
MrJ is offline   Reply With Quote
Old 11-25-2011, 08:34 AM   #2
MrJ
MrJ's Avatar
1976 28' Argosy 28
Dallas , Texas
anyone?!
Old 11-25-2011, 08:47 AM   #3
Originally Posted by MrJ View Post
anyone?!
Did you put the slots in the schlegal before you installed the weep hole covers?
If not, there's the "leaks".
Old 11-26-2011, 09:49 AM   #4
MrJ
MrJ's Avatar
1976 28' Argosy 28
Dallas , Texas
yes. I can see light through all the weep holes. 4 per window.
Old 11-28-2011, 07:36 PM   #5
Gypsy Jo's Avatar
1977 28' Argosy 28
Bullhead City , Arizona
I replaced the schlegle in my window and it still leaked until I replaced the gasket on the outside of the window . Also I had a window I thought was leaking but it was from one of the roof vents .The water was running down inside the skin and coming out along the window frame.
Jo
Gypsy Jo
1977 Argosy 28' Motor Home
Gypsy Jo is offline   Reply With Quote
Old 11-28-2011, 07:59 PM   #6
MrJ
MrJ's Avatar
1976 28' Argosy 28
Dallas , Texas
thanks, I'll look into that. Did you put calk at the edges where the vertical and horizontal trim meet?
Old 11-28-2011, 08:06 PM   #7
Gypsy Jo's Avatar
1977 28' Argosy 28
Not sure what you mean about vertical and horizontal trim. Use Vulcum or trempro not caulk.
Jo
Gypsy Jo
Old 11-28-2011, 08:28 PM   #8
MrJ
MrJ's Avatar
1976 28' Argosy 28
Dallas , Texas
I meant the gasket on the outside of the window. Are you talking about the vertical and horizontal trim, or the gray window seal?
Old 11-30-2011, 06:12 PM   #9
Gypsy Jo's Avatar
1977 28' Argosy 28
Gray window seal. Sorry no pics camera is broken.
Jo
Gypsy Jo
Old 11-30-2011, 09:04 PM   #10
Jo
There are two different gray motor home window seals.
One is for the vertical bar and the other is the trim seal, which goes around the top, the rear side and the bottom.
AS280 - Front (driver) sliding window latch dalefox Classic Motorhomes 13 01-05-2012 06:41 PM
HELP! kitchen window leaks Jcashcollect Windows & Screens 4 06-23-2011 10:41 AM
Rear window leak fixed! Really? I think so. 1964 GlobeTrottin 1960 - 1964 Globetrotter 0 04-30-2011 05:42 AM
Replace missing front window with jalousie? Cruisette Windows & Screens 6 03-31-2011 04:23 PM
1976 Argosy wrap window install Michael W Windows & Screens 0 02-28-2011 09:20 PM
