Old 07-23-2016, 09:05 AM   #1
1961 16' Bambi
1967 17' Caravel
Tempe , Arizona
Images: 27
Help -Window glass sticking to seal
I installed all new rubber seals/gasket to the window frames in my Caravel but now my glass is sticking to it so the windows can't open. I have finally got them separated but I don't want to leave the windows cracked open.
What should I apply so they don't stick????? I did order the correct seals from Vintage Trailer Supply and they are a perfect fit. It is hot in AZ but this is crazy.
Suggestions welcome.
Puggzilla is offline   Reply With Quote
Old 07-23-2016, 09:13 AM   #2
dznf0g's Avatar
Oswego , Illinois
303 aerospace uv protectant
-Rich-
Old 07-23-2016, 09:19 AM   #3
duncans's Avatar
2009 25' FB Flying Cloud
1973 31' Sovereign
Mount Angel , Oregon
Repeating Rich: 303, again and again and again. Ours now open easily, but I read this treatment should be performed annually. When stuck, open from the outside using a credit card, or like device. Ours were superheated in the closed position, in a fire. This worked for us, but did loose 2 seals before asking for advice.
duncans is online now   Reply With Quote
Old 07-24-2016, 07:21 AM   #4
1961 16' Bambi
1967 17' Caravel
Tempe , Arizona
Images: 27
Thank you for confirming the use of 303 aerospace uv protectant. I will start looking for some today! This has been a very unique experience. Thank goodness I still have some of the window seal material left. I may have to re-do one or 2 areas prior to applying the non-stick. I really appreciate both replies.
Old 07-24-2016, 07:30 AM   #5
Caffeinated's Avatar
2015 27' Flying Cloud
Portland , Oregon
Any pure silicon spray will work. I've heard good things about 303, which is available on Amazon, but I have Silicon and it works. It takes some repeated applications, and I clean the seals first with a little dish soap and water on a paper towel, then spray the silicon on a paper towel and apply.
Mike
Caffeinated is offline   Reply With Quote
Old 07-24-2016, 07:41 AM   #6
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
303 or silicon, I have used both and both work. Use often for best results.
MICHAEL
Old 07-24-2016, 08:09 AM   #7
2007 27' Safari FB SE
Any where the wind blows me , California
I use Vaseline. Works good
jaojamjab is offline   Reply With Quote
Old 07-24-2016, 09:35 AM   #8
TheDuke's Avatar
2016 30' Classic
The Beautiful Mountains Of Southwest , Virginia
Images: 68
X2!!!
"I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them." John Wayne - "JB Books" 1976.
TheDuke is offline   Reply With Quote
Old 07-24-2016, 10:18 AM   #9
2015 23' International
Charleston , South Carolina
Window poppers are another great solution. Even with silicon, ours are still hard to open and these work great to break the seal. Not sure if they fit older Airstreams. Might want to check before ordering.
http://www.seeyoudowntheroad.com/window-poppers/
FollySteve is offline   Reply With Quote
Old 07-24-2016, 10:58 AM   #10
FCStreamer's Avatar
2014 30' Flying Cloud
Or use your drivers license to stick between the window and the seal to help you open them.
I know, high tech...
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
Old 07-24-2016, 10:58 AM   #11
2008 25' Safari FB SE
london , Ontario
I've used Armour All and apply it annually.
tatone is offline   Reply With Quote
Old 07-24-2016, 11:01 AM   #12
2015 28' Flying Cloud
Newtown , Pennsylvania
I've cleaned and lubed mine a number of times, and they still stick. After I gave up, and the seals got covered with dirt and pollen, they work fine.
Bruce
50 amp, Awning package
2015 Ram 2500 6.7 TD, Blue Ox 1000 lb.
4 Lifeline AGM, Trimetric 2020
PD9160 converter, Prosine 1800 inverter
2x eu2000i Propane
AstroBruce is offline   Reply With Quote
Old 07-24-2016, 11:08 AM   #13
MomcatA's Avatar
2016 25' Flying Cloud
Glendale , California
As you can see, this is a common fact of Airstream life. All of the suggestions are helpful.
MomcatA is offline   Reply With Quote
Old 07-24-2016, 11:09 AM   #14
HoffmanP's Avatar
2014 27' FB International
Prospect , Virginia
I second this.
These do work well. I have installed 5.
HoffmanP is offline   Reply With Quote
Sticking Window Solution GLovedahl Windows & Screens 6 03-22-2015 08:20 PM
Help - Sticking Gate valve lebolewis Waste Systems, Tanks & Totes 2 09-28-2010 11:51 AM
replacing windows - glass, lexan, tempered glass? BrianY Windows & Screens 4 07-01-2010 12:08 PM
Hehr Standard Glass Seal toastie Windows & Screens 2 03-27-2008 07:55 PM
'56 Flying Cloud glass seal Dan Clayton Windows & Screens 2 04-02-2007 09:41 PM
