Old 07-24-2016, 06:17 PM   #29
SipStreamer
2010 20' Flying Cloud
Lakeside , Montana
AS windows: Great looks; lousy operation.
StreamDog is offline   Reply With Quote
Old 07-24-2016, 06:40 PM   #30
CruizinDux's Avatar
Eugene (Tracktown USA) , Oregon
I keep a disposable plastic putty knife in the drawer instead of the credit card. Wouldn't want to break the bank.
Sort of an aside but related. I was having trouble with the Fantastic Vent seals getting pulled out when I opened the dome. I called FV and they 1) suggested I spot glue the seals (I could not locate any evidence of any glue...relying on the ribbed insert to stay in the curb groove which was worthess) and to 303 protectant the dome, especially where it contacts the seal...also used to clean the fan blades apparently per their instructions.
FV doesn't sell itany more but suggested a non-petroleum based silicone oil. I found some on Amazon that was used as a lubricant in air guns and similar product for treadmills for roller lubrication.
I figured if works on the FV seals, it must work on the windows seals too. What I could garner on line is the pet based silicone products deteriorate the rubber over time...hence the non-pet based S/O.
I only did this a few day ago so have no history to report. However the manual in one place suggests 303 and in another "Slipicone" for the window seals. My dealer indicated the latter was silicone oil...base unknown.
The poppers are slick and maybe I'll revisit them down the road.
CruizinDux is offline   Reply With Quote
Old 07-24-2016, 11:15 PM   #31
Caffeinated's Avatar
2015 27' Flying Cloud
Portland , Oregon
I'm having the same problem with one of my Fantastic vent seals. What did they say to glue it with?
Mike
Caffeinated is offline   Reply With Quote
Old 07-24-2016, 11:17 PM   #32
Adiredneck's Avatar
2014 27' FB Classic
Vicksburg , Mississippi
I keep one of my old dog tags on my key chain. Flat, with rounded corners, it works perfectly to nudge open a sticky window!
"Hot meals, cold beer, dry bed & flush toilet - everything I look for in a wilderness experience..."
Adiredneck is offline   Reply With Quote
Old 07-25-2016, 12:23 AM   #33
CruizinDux's Avatar
Mike
Mike I bought something at a big box that worked with plastic in additional to the wood, metal etc. They mentioned superglue but I got the impression any general purpose glue would work. I wanted to stay away from a silicone caulk approach.
I'll take a look at the tube on Tuesday when I'm at the trailer and report back.
I put very small amounts in the groove at the joint and also at the start and end 4 corners. I tried to limit the glue in case I had to re-do someday.
Old 07-25-2016, 05:19 AM   #34
1967 26' Overlander
Spartanburg , South Carolina
Originally Posted by HCR View Post
Another vote for vaseline.
Vaseline will degrade many types of rubber. Silicone will extend the life of rubber seals while preventing glass from sticking to it.
Jacob D is offline   Reply With Quote
Old 07-25-2016, 05:30 AM   #35
Long Island , New York
All Airstream systems are designed for active use, including the window gaskets. If used often they don't stick.
303 Protectant is what AS recommends. Amazon carries it as wipes in a small plastic tub which is lightweight, easy to store, and has no liquid to spill.
https://www.amazon.com/303-30910-Aer...XGGFXF6JRA9DXV
All the other suggestions will work but also come with negative side effects IMO. As someone mentioned a very light layer of dust from constant window usage also helps.
Old 07-26-2016, 03:32 PM   #36
CruizinDux's Avatar
Mike
Mike I used Loctite: Vinyl, fabric & plastic. it is also labeled "Flexible Adhesive" I got mine at Jerry's in Eug but HD/Lowes in addition to AVE probably have it too. I liked that it worked for vinyl & plastic and was flexible.
Old 07-26-2016, 03:41 PM   #37
CruizinDux's Avatar
non pet based silicone on seals
I went with the silicone since F-Vents recommended the 303 only for the dome but silicone for the seals. AS in different pages indicates both.
Using a rag, I applied the first coat of silicone last Thursday. Today when I opened them the vent popped right up. When I released the latches on the windows...I could see the glass pop away immediately. I tried the arms and and the windows were free.
Today I added another light coat and tended to my other chores for another hour, but before leaving wiped them down and closed the windows.
Surely there is a bit of film about 1/8" wide along the edge of the window and maybe that will attract some dust. But I think I'll clean the windows next time and sty on the S/oil routine for now.
Old 07-26-2016, 03:48 PM   #38
Wise Elder
Jammer's Avatar
2010 30' Classic
I have tried a number of the suggestions upthread.
Talc works best. I use tire talc, which is unscented and designed to ...drum roll... keep rubber from sticking to things.
After five years, I still haven't had to re-apply it.
Old 07-26-2016, 05:08 PM   #39
Coaster's Avatar
Saint Augustine , Florida
I use the blue refrigerator card to hold the doors open when not in use. But a better fix would keep you from getting wet when it rains.
Coaster is offline   Reply With Quote
Sticking Window Solution GLovedahl Windows & Screens 6 03-22-2015 09:20 PM
Help - Sticking Gate valve lebolewis Waste Systems, Tanks & Totes 2 09-28-2010 12:51 PM
replacing windows - glass, lexan, tempered glass? BrianY Windows & Screens 4 07-01-2010 01:08 PM
Hehr Standard Glass Seal toastie Windows & Screens 2 03-27-2008 08:55 PM
'56 Flying Cloud glass seal Dan Clayton Windows & Screens 2 04-02-2007 10:41 PM
