Old 07-24-2016, 12:26 PM   #15
1977 31' Sovereign
Lynnwood , Washington
Use baby powder. Keeps windows from sticking to weatherstrips on your Airstream and lubricates door glass run channels in your car. Works like a champ. Baby powder is a must-have for every tool box.
Believe it or not, talcum is a lubricant.
Tom
TomKirk is offline   Reply With Quote
Old 07-24-2016, 12:27 PM   #16
PammieSue's Avatar
1988 32.5' Airstream 325
Vista , California
Just another thing that Airstream has been screwing up for decades and seemingly has no intention of ever fixing. Windows that stick. Tell me again why we think this is the best RV ever? We have windows that I cannot open at all, and Windows that even my Chris struggles to open, or shut for that matter. You would think that after this many decades Airstream would have fixed it. So why haven't they? I don't think they give a crap.
Dysfunctional Veteran- does not always play well with others. 19 a day is 19 TOO MANY.
(19 recently revised from 20, revised from 23, revised from 22. Even the VA is a work in process)
PammieSue is offline   Reply With Quote
Old 07-24-2016, 12:31 PM   #17
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
I use silicone spray, works very well. You can pick it up at any hardware store.
Silverflames is offline   Reply With Quote
Old 07-24-2016, 12:41 PM   #18
HCR
HCR's Avatar
Livingston , Full time traveler
Another vote for vaseline.
Airstream of Consciousness
HCR is offline   Reply With Quote
Old 07-24-2016, 12:55 PM   #19
PammieSue's Avatar
Vista , California
Chris says a dry silicone, or graphite powder works best.
Old 07-24-2016, 01:36 PM   #20
Registered User
Houston , Texas
We find that Silicon spray works fine, easy. BEST one we ever used is WD40 Silicon [not the oil]. Black and yellow can, flip top with permanently affixed nozzel. Regularly apply to all metal on metal [awning slides, etc] all windows, the window opening slides, and the metal flip up fasteners at screw-on. Great for all hinges, and of course, the hitch and trailer jack. Can find at Walmart, not in the oil dept, but separately, usually in the auto section. Home Depot also carries it, both about $6.
Candace is offline   Reply With Quote
Old 07-24-2016, 01:45 PM   #21
2002 25' Classic
Kalama , Washington
Not sure how talc powder behaves when wet, so some testing before applying to window seals might be prudent. On windows that are stuck (not extreme heat welded to seals), sometimes a little outward pressure applied when operating the handles helps. Do this by rotating the latches so that the locking arms press against the window frame. Lots of good uses for silicone… window seals surely one of them .
nwclassic is offline   Reply With Quote
Old 07-24-2016, 02:06 PM   #22
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
They both work.
TinCan
graysailor is offline   Reply With Quote
Old 07-24-2016, 02:27 PM   #23
Ray Eklund's Avatar
2014 25' International
Boulder City , Nevada
So... you wanted BIG windows... and now this happens.
If off onto dusty roads... be careful with the timing of what might adhere between your window and rubber. Not a stinking mess, but a dusty crust and grit to grind into your window glass edges, after closing, and then vibrating down the highways for six hours with the silicone/grit polishing compound you made possible.
The credit card works, but if you have no credit... something that can slide between the glass and gasket not tearing it made of plastic. You can also open the window from the outside and set the two window rods into their slots. Just have to set them inside to open...
Finger nails. Only if you want to loose them.
Be patient. Work both edges so not to break the window. You wanted big windows and this is your punishment. I liked the small crank vents on our 2006 23 footer. I just do not spend that much time in my trailer. I can sit inside at home all I want and look out of the window without all of this grief.
Human Bean
Ray Eklund is offline   Reply With Quote
Old 07-24-2016, 02:34 PM   #24
cac
2016 26' Flying Cloud
Tehachapi , California
Originally Posted by FollySteve View Post
Window poppers are another great solution. Even with silicon, ours are still hard to open and these work great to break the seal. Not sure if they fit older Airstreams. Might want to check before ordering.
http://www.seeyoudowntheroad.com/window-poppers/
I had Window Poppers installed on my 20' Flying Cloud, and can't wait to get them for the new 26U. They made opening windows EASY, even in rain! : )
cac is offline   Reply With Quote
Old 07-24-2016, 02:41 PM   #25
Displaced Beach Bum
beachbouy's Avatar
2016 30' International
Texas Airstream Harbor , Texas
Send a message via Skype™ to beachbouy
Which is better the 303 (30324) Rubber Seal Protectant or the 303 (30305) Aerospace Protectant?
We drag Mitzi a 2016 International Serenity 30 with Goodyear Endurance shoes, with an Equal-i-zer 1000 yanked around with a 2015 GMC Yukon XL SLT 4x4, 5.3L V8 ECOTEC3, 3.92 axle, 6-speed auto WBCCI #6111 AIR #107335
beachbouy is offline   Reply With Quote
Old 07-24-2016, 02:47 PM   #26
1967 26' Overlander
Spartanburg , South Carolina
Silicone spray works well on window seals, door locks and just about anything else you don't want to paint. NAPA has a tube of silicone paste called Silglide that works well too. Annual application is adviseable.
Jacob D is offline   Reply With Quote
Old 07-24-2016, 03:41 PM   #27
NWRVR's Avatar
2015 30' Classic
Sherwood , Oregon
Spay silicon on a cloth and rub cloth on entire gasket. Let dry and apply second coat. This lasts a year for me, nice to have stick-free windows.
2015 Classic 30A, Blue OX Sway Pro, 2016 F350 4x4 Ultimate Lariat crew cab SRW, LWB, 6.7 PSD, 20" wheels, Ingot Silver Metallic, DiamondBack tonneau cover, TrailFX wheel-to-wheel step bars.
Sold: 2014 25FB International Serenity
NWRVR is offline   Reply With Quote
Old 07-24-2016, 04:18 PM   #28
dznf0g's Avatar
Oswego , Illinois
I've never used the rubber seal product, but the uv formula only need to be applied every few years.
-Rich-
Sticking Window Solution GLovedahl Windows & Screens 6 03-22-2015 09:20 PM
Help - Sticking Gate valve lebolewis Waste Systems, Tanks & Totes 2 09-28-2010 12:51 PM
replacing windows - glass, lexan, tempered glass? BrianY Windows & Screens 4 07-01-2010 01:08 PM
Hehr Standard Glass Seal toastie Windows & Screens 2 03-27-2008 08:55 PM
'56 Flying Cloud glass seal Dan Clayton Windows & Screens 2 04-02-2007 10:41 PM
