Old 03-14-2015, 07:41 AM   #1
1969 27' Overlander
St. Louis , Missouri
HELP, window fell off
I have a 69 Overlander. I had the front window open and the entire window fell out. Luckily it didn't break , but the top hinge, which is supposed to be fixed to the top of frame, came off. It appears it was originally glued on. Wondering how to reattach. Im thinking epoxy or gorilla glue or something?
Noco is offline   Reply With Quote
Old 03-14-2015, 07:56 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
It should have been riveted to the sash, using bucked rivets.
To reinstall, drill out the old rivet remains, and use new pop rivets from the back side of the hibge to re-attach.
Old 03-14-2015, 07:59 AM   #3
1969 27' Overlander
Its just the curled bead that window hinges into. There were no rivets in it and there is no way to rivet it
Old 03-14-2015, 08:00 AM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Run a bead of Vulkem caulk down the back side of the hinge then rivet. If you want the bucked rivet look use Olympic rivets.
Old 03-14-2015, 08:02 AM   #5
Lumatic's Avatar
1993 34' Excella
Images: 16
That doesn't make sense. Photos?
Old 03-14-2015, 08:10 AM   #6
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Pictures pictures pictures
Don Hardman
1976 31' Sovereign
adonh is offline   Reply With Quote
Old 03-14-2015, 08:37 AM   #7
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Noco, If the extruded top of the window assembly has a curled edge it is supposed to fit into a opposite curled top piece. The top edge of the window frame should have this opposite curled lip riveted to the window frame at the exterior skin area or just at the top edge of the sash on the window frame itself. Look to reinstall the window by holding it up in front of the opening high enough to re-engage the curled top of the window into the curled top over the hinge plate on the window frame. If when installed you lift the window too high it will dis-engage the window unit from the frame again. You should have a support arm that keeps the window assembly from being raised too high that is connected to both the window assembly and the frame. Hope this helps, Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 03-14-2015, 01:12 PM   #8
1977 31' Sovereign
Lynnwood , Washington
Chances are, someone removed this window previously and failed to re-attach it properly.
I removed mine sevaral years ago and it was a two-man, two ladder job to re-install. My windows are double-pane, so they're heavy. And the front window is heaviest of all.
To re-install, window must be in the open position, near-vertical (something like 160 degrees) in order for the notches to properly mate completely along the entire length of the window frame.
You may want to R&R a smaller window to see how this clever hinge arrangement words.
Tom
TomKirk is offline   Reply With Quote
Old 03-15-2015, 06:12 AM   #9
1969 27' Overlander
Okay, I went out to my trailer to look again. The top curled piece is what fell off, it is what holds the window and creates the gutter above window. Looking at other windows, they were originally spot welded on. I'm not comfortable welding aluminum so I guess I'm going to attempt to reattach using Jb weld or epoxy or something.
Old 03-15-2015, 07:09 AM   #10
Baltimore , Maryland
I doubt they were spot welded. Airstream din't spot weld it.
Photos would be very helpful to solve this issue…
Old 03-15-2015, 09:58 AM   #11
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Upper window hinge piece
Noco, Frank is right! No Airstream (factory) built window unit would ever be attached with any adhesive. Nor were they welding aluminum together at the plant. Don't do that to repair your hinge issue. You should be able to look at the other windows on your trailer and see that factory installed hinge upper piece should be installed with rivets and sealant. If you cannot see this on your coach go look at other Airstream trailers of your same model and year in this forums member photo galleries or go to other sites like VintageAirstream.com. You will find many other sites that have loads of pictures that will provide you with the images that will help you repair this issue the correct way. If this piece was for some reason glued onto your trailer by a previous owner it doesn't mean that that was the correct repair . Without rivets attaching your upper hinge to the trailer I can guarantee you that your window will not stay attached to the trailer. If you will post some pictures of you hinge piece and the area just above your window opening on your trailer it would greatly assist us to correctly diagnose what is going on with your window hinge issue. Hope this helps, and Happy Trails, Ed
Old 03-15-2015, 10:12 AM   #12
1969 27' Overlander
The trailer is sixty miles away but I inspected all windows yesterday. If anyone is working on a 69, please help. The gutter above the windows also makes up the female side of the window hinge. There are two small rivets to keep the window from sliding out of the hinge, but the piece has no surface area to be riveted to the airstream! There are a series of spot welds on bottom, holding top of hinge and window in place! Every one of my windows has them in clear view. I will get pictures next time I'm out there.
Old 03-21-2015, 09:41 PM   #13
1969 27' Overlander
Finally was able to get some pictures. The piece in my hand is what fell off trailer. Where my index finger is is the only area which would fasten to window frame. The top is the gutter, the curved bottom is what holds the window up. The other picture shows the small tack welds holding in place. I'm not going to weld, but clearly I can not rivet, so I'm thinking epoxy or JB weld???
ID:	234720   Click image for larger version
Old 03-22-2015, 01:20 PM   #14
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Broken hinge part
Noco, It appears that the part in your hand has stress broken/separated from the aluminum window surround. See if you can locate where it was originally located on the trim edge of the glass window extrusion. It may be that you could have that piece tig welded back together but it would involve being able to dis-assemble the surrounding aluminum from the glass. It might be easier to find a same size window from a scrapped trailer of the same model/year from one of the Rv parts places that deal in scrapped parts sales. You should try Colaws RV parts in Missouri. There is also a parts supply place in Utah that was formerly called CherokeeRv.com that stocked a lot of windows/frames from lots of A/S models. You need either the size measurements or an Airstream part number to have them check the ones they have in stock. This would likely be the best way to fix your issue. Ed
window casings fell off snickers Upholstery, Blinds, Walls & Interior Finishes 1 05-13-2013 07:35 AM
Need Help! Wheel Fell Off! Lots of Damage! jayk47 Vintage Kin 24 07-18-2007 08:47 AM
Cover for sewer hose fell off! Safari-Rick 2005 Safari 6 07-30-2005 09:27 AM
Dometic door fell off rochar3 Refrigerators 1 07-24-2004 12:17 PM
Tailgate fell off my GM pick up! davidz71 Tow Vehicles 23 03-19-2004 07:02 PM
