Old 04-11-2008, 08:30 PM   #1
Silver Threads's Avatar
2000 25' Excella
Kingston , Tennessee
Help removing old clips
I tried the search function and after reading 2o threads and not finding an answer, I decided to just start this one. Forgive me if it is out there somewhere !
Can someone tell me how to remove the old clips from the windows without breaking the glass. The old ones are rusty. We tried to pull on them but they didnt budge. I borrowed this picture so you could see what I am talking about. Any help is greatly appreciated!
Tammy
John & Tammy Adams
Silver Threads Custom RV Curtains
2000 Airstream Excella | AIR 15902
https://www.etsy.com/your/listings
Silver Threads is offline   Reply With Quote
Old 04-11-2008, 08:35 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
They are "glued" in place by the rubber holding the clips on the window.
You should be able to spread the clips slightly using a putty knife and a (very) little pressure.
Old 04-11-2008, 08:36 PM   #3
Mel
Mel's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Hi Tammy -
We replaced all of the clips on our '67, and I do understand the stress of removing the old ones without breaking a window - it's scary! What worked for us was to use PB Blaster to soak the clips (inside and out - open the window slightly so the excess Blaster drips on the ground). After they soaked a bit, I used a razor blade to gently pry between the clip and the glass. Many of them freed up at this point. A couple of them required a bit more persuasion with a thin putty knife. Take your time. It's worth the trouble, as the new, non-rusty clips look wonderful! Good luck ~
Mel
Mel is offline   Reply With Quote
Old 04-12-2008, 08:12 AM   #4
2000 25' Excella
Thank you both very much!
John & Tammy Adams
Old 04-12-2008, 08:29 AM   #5
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
Great thread!! I, too, have been afraid to force them off in any way for fear of breaking the glass. So....I have had a mix of new and old ones on the coach.
I will now go bravely forward and try the PB Blaster.
I used small pieces of rubber to create a tighter seal on the ones I have been able to replace. Does anyone have any other tricks they have used to get the new clips to grip the glass and stay put?
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 04-14-2008, 11:19 AM   #6
USS REQUIN 481
Pariscope's Avatar
1963 19' Globetrotter
1988 25' Excella
Reynolds , Georgia
Silver Threads,
Take a moment and get me to your phone number how to send a inquiry to your webpage. We want a different configuration to our goucho bed. All one piece and extended by 7" out toward door opening. For a larger bed.
paris@pstel.net
Do you make the mattresses also or who should I get for that?
"rivit,rivit"
Pariscope is offline   Reply With Quote
Old 10-05-2013, 07:32 PM   #7
1967 22' Safari
Concord , California
Thanks, guys! The PB Blaster and razor blade worked perfectly!
LouiesRV is offline   Reply With Quote
Old 10-05-2013, 07:59 PM   #8
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
Pb blaster? I have to replace several and the new ones came today.
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 10-07-2013, 11:00 AM   #9
1967 22' Safari
Cliff
It's a penetrating lubricant for frozen nuts & bolts, kind of like Liquid Wrench. You can get it at your local hardware store.
Funny Clips Jimandrod Fun & Games 4 01-30-2012 03:22 PM
Corning clips! pinkflamingoes Windows & Screens 0 07-26-2006 01:14 PM
'67 Window clips. chalcedon Windows & Screens 1 03-29-2006 10:38 PM
removing floor without removing shell nevisstudio Repairing/Replacing Floor &/or Frame 11 07-24-2005 11:47 PM
Curtain clips? M. Neibuhr Upholstery, Blinds, Walls & Interior Finishes 4 08-05-2003 11:25 AM
