Old 09-28-2012, 06:35 PM   #1
cuyeda's Avatar
Long Beach , California
Hehr window, rebuild?, install?, rivets?
I have a few questions before the windows are reinstalled (1958 Traveler).
1. For the backframe D gaskets, are the corners cut at 45 degree angles, or straight cut?
2. Butyl tape was originaly used as the sealant along the top of the backframe. I don't plan on taking these windows apart again. Is it better to use a PL urethane Vulkem to seal the top?
3. What kind of rivets fasten the center rail, and frame together? Where can I buy the rivets?
4. Looking for galvanized screen material. VTS is out of stock for a month! My window project is stalled until I can get the screen material. Or, has anyone installed the screens with the windows installed already?
1947 Curtis Wright
1958 Traveler 18'
cuyeda is offline   Reply With Quote
Old 09-28-2012, 07:17 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Cliff,
I purchased the galvanized screen material from a local glass shop.
Bill
Just my personal opinion
Old 09-28-2012, 07:34 PM   #3
cuyeda's Avatar
Originally Posted by wkerfoot View Post
Cliff,
Bill
I was at a glass shop today ordering new glass for my windows. No screen material. However, there is a local screen shop! I will try that tomorrow! Thanks.
1947 Curtis Wright
1958 Traveler 18'
Old 09-28-2012, 07:42 PM   #4
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Cliff,
Take a sample of the screen with you.
Bill
Old 10-05-2012, 12:27 AM   #5
cuyeda's Avatar
Update:
Galvanized screen material no where in sight. I broke down, and bought charcoal aluminum screen material from Lowes. There is also bright aluminum color. I am satisfied with the fit, but time will tell if it holds up.
For the back gasket, I used a 45 degree cut, but not all the way through. I end up with one long piece that wraps around each corner. Just a little practice cutting with a razor.
For the top window frame sealant, I used vulkem instead of the original butyl tape.
Still would like to know the type of rivets used for window frame.
1947 Curtis Wright
1958 Traveler 18'
