Old 11-20-2010, 08:04 AM   #15
1958 26' Overlander
Lander , Wyoming
California built double door! I'm replacing some of the lower segment panels currently. Ed
n2batr is offline   Reply With Quote
Old 02-20-2011, 10:35 PM   #16
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Hey Mike,
It sounds like you solved the problem.Curious though about the bulb seal.Mine are flattened on the 65'too.I was going to use a D style gasket I got from Inland as it supposedly seals better.Now I am wondering if I use both?
Main reason for my post is to inquire as to how you got the top screw out as mine is pretty rusted.Give me the details.Thanks,Steve
bwaysteve is offline   Reply With Quote
Old 02-21-2011, 07:14 AM   #17
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Originally Posted by bwaysteve View Post
Hey Mike,
Hi Steve,
Yes, I had to remove the screw to remove the window (I needed to replace the glass). Mine simply screwed right out. After bending up the end of the drip cap after drilling out the end rivet, the window just slid right out.
I'm not sure if your window is the same style, can you send a pic of the window in question open and closed? The bulb seal for this window is more an air seal than water seal. The window frame has about a one inch inner lip which provides a great barrier for water intrusion. I couldn't put another seal on my window even If I wanted. With the new bulb seal I need help from the outside to close it.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Need Standard Hehr window... cdmagda Windows & Screens 0 06-06-2010 12:01 PM
'63 Sov-Hehr window replacement, help Dugger10 Windows & Screens 7 05-29-2009 04:16 PM
Hehr window operator replacement questions 63air Windows & Screens 5 05-21-2008 05:25 PM
looking for a 1962 HEHR Side Window! A-Merry-Can Windows & Screens 4 07-02-2007 02:57 PM
Hehr window Judy Barde Windows & Screens 2 05-22-2007 05:39 PM
