Old 03-27-2008, 07:38 PM   #1
toastie's Avatar
1955 22' Safari
Great Lake State , .
Hehr Standard Glass Seal
Restoring all my widow to our 1955 Safari, and my question is, should I use an adhesive when installing Hehr Standard Glass Seal?..........thanks
toastie is offline   Reply With Quote
Old 03-27-2008, 08:04 PM   #2
1958 26' Overlander
Lander , Wyoming
I'm not sure if there was sealant on the original or not. I'm rebuilding the hehr windows on my 58 and I found you need some sealant on them to fix them to the aluminum rim. I only put sealant on the inner edge which fixed the grey gasket in place them used butyl tape on top of that, then the glass which is held by the inner aluminum brackets. This seemed to work well. Hope that makes sense. Ed
n2batr is offline   Reply With Quote
Old 03-27-2008, 08:55 PM   #3
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
I did not use any adhesive when rebuilding the windows on the 1954 Liner. The small pieces of inside trim push the glass against the seal and hold it in place.
Bill
Just my personal opinion
Is this standard layout bertro Repairing/Replacing Floor &/or Frame 2 04-13-2007 09:03 PM
'56 Flying Cloud glass seal Dan Clayton Windows & Screens 2 04-02-2007 10:41 PM
Vertical lip seal and trim seal for Classic Motorhomes rdm General Motorhome Topics 16 05-22-2006 08:49 PM
Standard vs. option? silverback 1997 - 2004 Bambi 7 07-19-2003 03:00 PM
