Old 02-25-2011, 09:13 AM   #1
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Hehr Standard Backframe Gasket Installation for '58
I've got four Hehr windows that require new backframe gaskets. Some recommend using Olympic Rivets to install this gasket but was wondering if regular pop rivets of sufficient length would be suitable. The gasket does not mount in the trailer skin, but on a raised L-frame of sorts, so there is no risk of leaks. VTS directions also state to use just adhesive, no mention of rivets.
http://www.vintagetrailersupply.com/...p/vts-199x.htm
I'm interested in your thoughts and opinions on installating this gasket and curious how this installation went for others.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 04-11-2011, 09:52 AM   #2
55-ArtStream's Avatar
1955 26' Cruiser/Overlander
Parowan , Utah
Images: 13
Mike, my ’55 Overlander has 8 windows and one rear storage door which all have the same backframe gaskets. All of my windows were pop-riveted in place at the factory. I’m replacing them the way I found them. Can’t see how a better rivet would keep it from leaking considering how much gasket there is on both sides of the frame. Not to mention the fact that I’m rubbing a small amount of RTV silicone on each rivet before inserting them.
On the Road, Somewhere in North America.
55-ArtStream is offline   Reply With Quote
Old 04-11-2011, 11:18 AM   #3
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
That's very interesting, Spike. They used POP rivets for all of those? Hmmm.
Mine were all buck riveted which is why I chose to go with Olympics on the first window I did. But it did seem like overkill with the gasket and vulkem I used. Looks like I'll use POP rivets for the remaining 3 windows and baggage compartment.
1958 Overlander
4CU 1st VP
Old 04-11-2011, 11:42 AM   #4
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
I used pop rivets on most of mine also Mike. It was hard to keep the gasket in place while inserting the rivets so I applied clear silicone to the back of the window then clamped the window and gasket back in place on the trailer until the silicone dried and then riveted. this kept the gaskets a little straighter.
Doug
It's not worth doing if you're not having fun.
http://tinman54.blogspot.com/
http://www.airforums.com/forums/f228...tml#post616014
tinman54 is offline   Reply With Quote
Old 04-11-2011, 01:13 PM   #5
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Doug
Doug,
I know what you mean by the gasket moving around. Next time I'm going to glue the gasket to the backframe using black gasket adhesive. After this sets up I'll apply a bead of black silicone (Trempro 644) to the back of the gasket then rivet the gasket and frame to the body.
1958 Overlander
4CU 1st VP
picture of D gasket bwaysteve Leaks - Weatherstrips, Gaskets, Caulks & Sealants 23 02-26-2011 04:46 PM
Will gasket material seal the rear bumper storage? tvanwave Bumpers & Bumper Storage 0 01-31-2011 04:00 PM
Part # Duo therm penguin gasket? HCR Furnaces, Heaters, Fireplaces & Air Conditioning 0 01-09-2011 12:27 PM
