Old 03-18-2012, 12:07 PM   #1
GlobeTrottin's Avatar
1964 19' Globetrotter
Chelsea , Michigan
Hehr 1964 window glazing strips
I replaced one window last summer and used the pvc strips from vts. They were hard to fit and didnt really seem to snap in securely. Checking today I find that 3 of 4 are missing and presumably fell out. Really not working for me! Any ideas? How about home window glazing compound? Or maybe a trick to make those strips stay put?
GlobeTrottin is offline   Reply With Quote
Old 03-18-2012, 12:18 PM   #2
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Try clear silicone between strips and glass. Just a light coat should hold the strips until you want to remove them. If you want a second option use double faced tape applied to edge of window then install strip and trim back tape at edge of strip. Apply a bead of Acryl-R or Parbond to seal top exterior edge of strip to glass. Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
New project | 1964 Overlander Janet H 1960 - 1964 Overlander 90 12-19-2013 11:31 AM
Rivets for window rock guard hinge arcamedies Rock Guards, Segment & Window Protectors 5 12-30-2012 06:20 AM
'89 excella - Plastic window trim cracked.. epoxy to repair? mikeandnora General Interior Topics 6 05-31-2012 07:18 PM
Front Window Protector Tip Bluto Rock Guards, Segment & Window Protectors 7 03-17-2012 09:44 PM
window weatherstripping advice tlynn87 Windows & Screens 4 03-15-2012 08:27 PM
