Old 05-20-2007, 01:16 PM   #1
1973 31' Sovereign
Sandusky , Michigan
glue for seal replacement?
Just wondering what the type of glue to use for seal replacement on the windows on my 31 footer? Is it a product locally available or a special product I need to order Thanks again Steve
firebird is offline   Reply With Quote
Old 05-20-2007, 01:38 PM   #2
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Welcome!
Hi Steve, Welcome. I've heard good things about 3M marine adhesive. Try the search bar in the right upper corner lots of info there.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 05-20-2007, 02:17 PM   #3
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
I believe this is the stuff sold by Inland RV - you can get it at an auto parts store also.
Old 05-20-2007, 02:22 PM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
That's the stuff!
I got mine at a NAPA store.
Richard
Old 05-20-2007, 04:10 PM   #5
1973 31' Sovereign
Sandusky , Michigan
thanks very good
thanks Steve
Old 11-03-2010, 07:45 PM   #6
adore's Avatar
1977 Argosy Minuet 6.0 Metre
Mont-Laurier , Québec
I can't see the picture...
Originally Posted by azflycaster View Post
That's the stuff!
This is supposed to be the glue for seal replacement of the windows... but I can't see the picture. Could you please resubmit or give the name of the product. I have a Nappa store here where I can probably get the product. Thanks!
adore is offline   Reply With Quote
Old 11-03-2010, 08:35 PM   #7
3M8008 is the black super weatherstrip adhesive to use.
DO NOT use the yellow adhesive.
Old 11-03-2010, 08:43 PM   #8
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I used the gaskets from Andy. Worked great and stopped all my window leaks. The adhesive on the back of the gasket is very good. If you have your frames clean and free of any dust or oil, you won't need much adhesive as they stick extremely well. You do need to use a little adhesive in the corners.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 11-04-2010, 06:38 AM   #9
adore's Avatar
Many thanks!
I got the gaskets from Can-AM RV Center and there is no adhesive on them. With the instructions from Andy and the name of the 3M product (3M8008), I will be OK. Thanks to all those who responded.
A. Doré (Mont-Laurier, QC)
Old 11-04-2010, 09:34 AM   #10
You must have received the original double flared gasket.
The "D" gasket is a far better upgrade to use.
It does have the adhesive backing, that can be used, but for additional gasket security, the 3M8008 can also be used.
Old 11-04-2010, 01:14 PM   #11
1978 28' Ambassador
Savannah , Georgia
Finally finished replacing all the window gaskets. Closed and locked the windows for 3 days. Some of the gaskets moved a little when compressed. Can see the edge of the gasket around the edge of the window frame. Really am pleased with the knowledge they are now watertight. Come on rain!
Skamper1 is offline   Reply With Quote
Old 11-04-2010, 01:28 PM   #12
When that rain comes, how about redirecting some of it to southern California.
Here, we go to a movie, to see rain.
Old 11-04-2010, 02:20 PM   #13
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Ok, ok, Andy, I've gotta ask. Why not the yellow stuff (sometimes lovingly called Monkey Snot)?
Lynn
WBCCI 21043
Old 11-04-2010, 02:30 PM   #14
Lynn
Hi Lynn.
The yellow stuff is cheaper. So.......why don't the auto manufacturers use it???
Because, it does not have the holding power of the black stuff.
That's why the black stuff is called "Super".
And besides, the snot stuff is exactly that, snotty.
Water heater replacement Craig Water Heaters, Filters & Pumps 36 12-18-2014 09:13 AM
Tambour Glue? 74Sovereign Cabinets, Counter Tops & Furnishings 10 10-04-2002 03:05 PM
Water inlet key replacement Road Ruler Fresh Water Systems 7 09-03-2002 09:07 PM
Door Lock replacement? 3Ms75Argosy Doors & Locks 2 08-15-2002 11:12 PM
Accordian Door Replacement Tamara Upholstery, Blinds, Walls & Interior Finishes 2 06-17-2002 12:08 PM
