Old 01-25-2006, 03:07 PM   #1
mtnman's Avatar
Collettsville , North Carolina
Glass replacement
I have a curb side window on my 79 Argosy that has 2 cracks in it and I want to get it replaced. I think it must be made of plexi glass or something other than glass. My intentions were to remove the whole window and take it to a glass repair store and let them put the new window glass in. The window opens and has 2 rivets at the top. It also has the little rain gutter which runs around the top and about 3 to 4 inches down each side of the window. Can anyone tell me how to remove the window? I searched window repair and found nothing that would help me.
mtnman
mtnman is offline   Reply With Quote
Old 01-25-2006, 05:55 PM   #2
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
The window and frame...
removes fairly easily (like your side compartment doors). Unscrew the side arms that push the window up/out. From standing on a ladder, swing the window up higher until it unlatches from the top. Be careful not to bend the "hinges", as it makes installation much harder. Have someone handy to catch it if you should drop it!
That's it! I don't know how to get the window out of the frame though.
Marc
Old 01-25-2006, 06:22 PM   #3
mtnman's Avatar
Marc
That easy?!!! I will try it tomorrow. If I get the window to the glass place, they can take it out of the frame.
mtnman
Old 02-03-2006, 08:02 AM   #4
mtnman's Avatar
You were right, that was easy. I now have a new window in my coach!!
mtnman
Old 02-03-2006, 11:28 AM   #5
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
How Did You Remove and Replace Glass Itself
Removing the window assembly is easy. Please tell us how you replaced the curved glass. Inquiring minds want to know.
Ken
Alumaholic is offline   Reply With Quote
Old 02-03-2006, 11:54 AM   #6
Pschoerrn's Avatar
1971 29' Ambassador
Braunschweig , Germany
mtnman,
with what did you replace the old glas? Was it possible to put new glas in? I always thought it would be too hard due to the slight curve in the windowframe...
Bjoern
Björn H. Adam
Wolfenbuettel, Germany
AirstreamForumsMember No. AIR 5535
Proud Owner of a 1971 Ambassador 29' called "Dave"
-A stranger is a friend you just haven´t met before!-
unknown irish
davetheairstream
Pschoerrn is offline   Reply With Quote
Old 02-03-2006, 12:14 PM   #7
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Originally Posted by Pschoerrn
mtnman,
Bjoern
Bjoern,
IIRC mtnman has a Minuet which has the plexiglass windows in it to reduce weight. That stuff will bend in a curve. If you have the glass like we do get ready to spend the big bucks for replacement windows. Or stuff a piece of scratch resistant Lexan in.
Aaron
WBCCI #XXXX AIR #2495
Old 02-03-2006, 12:25 PM   #8
Pschoerrn's Avatar
1971 29' Ambassador
Thanks Aaron,
Lexan was my way to go, too. "Real" Glas for Replacement is hard to get over here, as there are nearly no Airstreams for gutting...
Bjoern
Björn H. Adam
unknown irish
davetheairstream
Water heater replacement Craig Water Heaters, Filters & Pumps 36 12-18-2014 09:13 AM
Wondering what kind of glass to use for replacing all windows in 1958 Traveller williamhenshall Windows & Screens 3 08-19-2007 07:15 PM
Curved side window replacement michel88 Windows & Screens 7 09-29-2006 09:20 AM
How to remove the glass from windows? Andy R Windows & Screens 2 06-19-2002 09:30 AM
Accordian Door Replacement Tamara Upholstery, Blinds, Walls & Interior Finishes 2 06-17-2002 12:08 PM
