Old 03-14-2012, 03:43 PM   #1
1970 31' Sovereign
Burnsville , North Carolina
Gaskets for 1970 Sovereign
Here are photos of the gaskets on my side and back windows which hold the plastic widows in place. I am replacing these windows. Where do I find this material and why are the back and side windows different? Finally, this is single pane plastic. Do I need to set the new panes in putty? Thanks for any help out there!
Bill
ID:	153377   Click image for larger version
ID:	153379   Click image for larger version
CeloNC is offline   Reply With Quote
Old 03-14-2012, 06:09 PM   #2
moparjohn's Avatar
1973 25' Tradewind
Ringoes , New Jersey
gasket
Bill, I am not an expert, but I belive that gasket material is no longer available from Airstream (BUT it should be "friendly hint") It appears yours is mostly there, just loose. You might be able to rebuild them. Check out Wasagachris;s thread, he has rebiult some windows. Others here have as well. The second gasket I am not sure of, it looks a bit like the weatherstrip from the window frame, that seals it ti the window fram on the trailer. That is available, as well as a newer style. Hope this helps. MPJ
moparjohn is offline   Reply With Quote
Old 03-15-2012, 07:17 AM   #3
1970 31' Sovereign
Thanks moparjohn. I'll stop hunting for the gasket in the first picture and find a substitute. The black gasket (on the rear window) is much smaller and stiffer than the material used on the frame itself. I'll check Vintage and Inland RV.
Bill
sovereign
Under Consideration: 1970 Sovereign Int'l CarrieSue Trailer Values 19 04-01-2012 10:01 PM
Soon to be for sale. What's it worth? garth66 Trailer Values 7 03-15-2012 08:18 PM
Looking for a guide Mrs.Mod On The Road... 20 03-14-2012 10:06 PM
Need advice before buying a Sovereign with water damage emanboulay Trailer Values 17 03-14-2012 01:48 PM
