Old 02-16-2006, 07:09 PM   #1
1973 31' Sovereign
Okeechobee , Florida
Gasket Glue
Hi!
Good Evening to all. Time to get back to work.
The gaskets have arrived and we obviously need to get a bit of adhesive to adhere them permanently. What is recommended? This is going to be a long road so I'd like to go down the right path. The gaskets are the black foam rubber with double flanges. PS-It is identicle to what we are scraping off.
Since we plan to purchase some aluminum rivets tomorrow it would be nice to be able to get the glue, as well. The rivets are for the dome light area as the plastic covers are warped and cracked, so since we have mostly sun here and plenty of vista views, we can afford the slight reduction of sunlight!
Hope all is well in the land of AS. I'm back to work.
Dera
dmuszick is offline   Reply With Quote
Old 02-16-2006, 07:13 PM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Dera,
I use 3M weatherstrip adhesive...got it from NAPA IIRC. Also run a board search for Window weatherstrip...there is something about the way you install the adhesive that can make the job simple or a mess if you do it the other way.
Aaron
WBCCI #XXXX AIR #2495
Old 02-16-2006, 09:01 PM   #3
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Originally Posted by wahoonc
Dera,
I use 3M weatherstrip adhesive (snip)
Aaron
aka "monkey snot." Well, only if you buy the original yellow kind. They also market a black version now, and it does not bear the relevant resemblance.
Lynn
WBCCI 21043
Old 02-18-2006, 09:58 PM   #4
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
That's Snot Right!
Lynn, You can check with Ingrid (PINKFLAMINGOS) on the way to install the adhesive and gasket to make sure, but I believe the correct and less messy way is to put a coat of adhesive along the door/window frame and also on the backside of the gasket. Use two people to do the install. Wait for the adhesive to be just tacky to almost dry. Then stick the gasket to the frame being careful to place it correctly the first time as it is difficult to remove if done wrong and ruins the gasket. Good Luck...Ed
BIGED52 is offline   Reply With Quote
Old 02-19-2006, 08:48 AM   #5
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Yep, that sounds about right. I installed new rubber around the cabin door with yellow monkey snot six or seven years ago. You apply the stuff in a relatively thin coat on both surfaces and let both become tacky. Then stick it all together. When they're tacky, they'll stick to each other readily, so I was able to do the whole job alone.
But before I get to gasket work (and windows), I have to complete my surprise frame droop job, which is coming along well and, I hope, will continue well if the weather improves and holds.
Lynn
WBCCI 21043
Old 02-19-2006, 10:00 AM   #6
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
where to get gaskets
I just did an emergency replacement of my door gasket while on the road. Lowe's rubber (not foam, but maybe not as good a real black gasket material) door gasket and peel-off sticky back. Takes an elephant to close, but worth doing until I get home.
I need to do all the windows. I got some gasket from Inland RV a couple years ago to do the access doors. Where can I order the right stuff and is it different for main door, windows, and access doors?
Old 02-20-2006, 02:29 PM   #7
Some dealers carry those gaskets.
You can also see them on a couple of web sites.
Different gaskets are used for different year trailers. You must be specific as to which year.
Exhaust ALANSD Airstream Motorhome Forums 44 11-30-2003 09:23 AM
Stupid Human Tricks airstreamcaravel General Repair Forum 12 11-20-2002 02:08 PM
Tambour Glue? 74Sovereign Cabinets, Counter Tops & Furnishings 10 10-04-2002 03:05 PM
Source for window gasket jaiman Windows & Screens 2 09-07-2002 09:16 PM
Blinds ALANSD Upholstery, Blinds, Walls & Interior Finishes 35 04-01-2002 01:54 AM
