Old 10-27-2017, 08:38 PM   #1
1976 31' Sovereign
Mill Valley , California
Gas for new double pane build???
Alright Airstream Wizards, here is a question I cannot find answer on forums.
I am about to put all my double pane windows back together after following several threads and blogs. No one mentions the need for Argon gas, until my buddy did today as he stood over my perfectly polished frames and windows.
As you can imagine, panic set in my heart. Am I really going to have to learn a whole other thing. Am I crazy to just reassemble without the gas.
Signing off as... "terrified to wake up with foggy windows next month"
GiftingGirl is offline   Reply With Quote
Old 10-27-2017, 09:09 PM   #2
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
Double pane window usually have desiccant in the metal frame to absorb the trapped moisture. You have to take the frames apart and put new in. The glass is siliconed to the frames.
Inert gas filled frames came later and would require some expertise.
If you could have a superpower, what would it be?
I chose America
Bigventure is online now   Reply With Quote
Old 10-27-2017, 10:17 PM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
If you rebuilt your double paned vintage Airstream windows with Argon trapped between the panes, you would probably be, if not the first, then one of very few who have this.
If you are that worried about the prospects of finding fog between the panes, then do what so many other refurbishers have done, and just rebuild them as single paned windows.
Good luck--stay away from the slippery slope!
Old 04-03-2018, 01:14 PM   #4
1976 31' Excella 500
Chappell Hill , Texas
No gas was used at the factory. Just desiccant to capture residual moisture. If they have moisture its because they have a leak and no amount of desiccant can help that.
tbashin is offline   Reply With Quote
Old 07-12-2018, 06:14 PM   #5
Greer , SC
31 foot 1974 International Land yacht.
Glad this question was asked. I am in the process of taken them out, and was going to pull them apart, clean them, put them back together, etc...
A couple of questions.
1. What is desiccant?
2. Do I need to buy it somewhere, and apply?
3. If so, how is it applied? Spray, gel?
Another question about taking apart the double pane windows.
4. How do you clean them?
5. If I clean off the film, what do I replace it with?
6. Soap and water?
Thanks.
orozcom is offline   Reply With Quote
Old 07-12-2018, 06:31 PM   #6
2007 22' International CCD
In double pane window assemblies, there is an aluminum frame sealed into the glass sandwich with black urethane sealant to keep moisture out. Argon is the gas of choice. The desiccant is silica gel beads inside the aluminum frame parts. The frame has a bunch of smallish herringbone-shaped slits in it inside the sealed unit so the desiccant can do its job.
That said, I have NO idea where you might get this material to build a unit. It's usually done where windows are built, and takes special machinery. Most Airstream folks just get rid of the inner pane, and go to single glass in the original window frames.
Old 07-17-2018, 09:18 AM   #7
Greer , SC
Thank you for that reply. I appreciate it. That makes me ask another question. Hopefully this will save me some money!
So I have a number of windows that are double pane, and the film on the inside is terrible. I was going to take them apart, clean them up, soap and water I guess.
You say just convert from double pane to single pane. If I do that, then I will have all of these inner pane just laying around. Are both panes exactly alike, or is there a difference between the inner pane, and outer pane?
The reason I ask is that one of my windows is shattered. I thought about buying a brand new window with the frame. They don't sell just the curved glass, you have to buy the window with the pane in it. I thought if the inner pane is exactly like the outer pane, then I could just clean it up, and put it on the broken window pane. Does that sound reasonable? Or am I just wasting my time, and need to order a new window?
Old 07-17-2018, 10:52 PM   #8
Hopefully some one with the answer will come by and chime in. Iíve run out of knowledge at this point.
Double pane to single pane window conversion ronstory Windows & Screens 8 10-07-2017 07:38 AM
Source of gasket for double pane to single pane conversion? Taylormade Windows & Screens 5 04-05-2016 09:07 PM
how to remove inner plexiglass pane of double paned oval window? ray henton Windows & Screens 1 04-15-2012 05:04 PM
Double Pane Window dbaverb Windows & Screens 11 12-06-2003 09:52 AM
bad tint film in double pane window wcdelorme Windows & Screens 11 05-16-2003 02:53 PM
