Old 03-18-2007, 07:49 PM   #1
1956Safari's Avatar
1956 22' Safari
Ossining , New York
Images: 16
Galv. Heavy Gauge Screen Purchase
Hi all, I need to replace all the screens in my vintage AS and was wondering if anyone knows where I can buy the screen material in smaller quantity?
I know I can get it in 100 ft rolls - 36" 18x14 Galv. Screen Code: 1115088 Hanover Wire Cloth, but its $85! Anyone else need any? I would be happy to share or split it up since I have no need for 100 feet. Or better yet, does anyone have a partial roll?
Welcome to BuilderDepotsells it as mentioned above for $84.52.
1956Safari is offline   Reply With Quote
Old 03-19-2007, 06:04 AM   #2
1956Safari's Avatar
1956 22' Safari
Ossining , New York
Images: 16
Galv. heavy window screen
Ok then, any other sources of screen at a resonable price?
Old 03-19-2007, 06:14 AM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I thought the ordinary hardware store variety would work OK? Is there a specialized screen I need to know about? If so I would be interested in sharing a rolll. Is this heavy duty screen any more difficult to install?
Old 03-19-2007, 06:16 AM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I have replaced my screen a few times. I can find a close match at home depot for a few dollars.
Richard
Old 03-19-2007, 06:21 AM   #5
1956Safari's Avatar
1956 22' Safari
Ossining , New York
Images: 16
Heavy Screen Source
According to RJ's great "how to" site, he specs galvanized steel screen which my Home Depot does not carry. I did buy the screen roller tool at Blaine.
RJ's site: http://vintageairstream.com/floyd/re...n/windows.html
Old 03-19-2007, 07:00 AM   #6
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
If it is a special or vintage material that you are looking for, then you might get lucky at your local mom and pop hardware store, like Ace or True Value, or preferably even smaller than that.
If you just want to match the look, then aluminum screening should suffice, which is available just about anywhere in small quantitites.
Uwe
www.area63productions.com
Old 03-19-2007, 07:31 AM   #7
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I'd personally go with nylon screen, it won't rust or corrode, is cheaper and easier to keep clean. Also it is easier to cut to shape for our windows. The down side is it will tear easier.
Old 03-19-2007, 07:47 AM   #8
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
I have used charcoal grey fiberglass screen from the big box stores, it looks like the original, installs easier and is cheap to purchase.
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 03-19-2007, 07:56 AM   #9
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Another advantage of Nylon screen is that it returns to it's original tension if it is accidentally stretched. Galvanized and/or Aluminum screening usually stays stretched, making it look baggy.
Inquiring toddlers and even doggy noses can do amazing things to a screen in a matter of nanoseconds..
Uwe
Old 03-19-2007, 08:43 AM   #10
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
I used black nylon since it is easier to see through - though a lighter color makes it a little more private, somewhat harder to see into at night... .
Old 03-22-2007, 03:49 PM   #11
Solar screen material works wonders, day and night.
Old 03-22-2007, 06:53 PM   #12
1956Safari's Avatar
1956 22' Safari
Ossining , New York
Images: 16
Solar Screen
Andy, What type do you suggest? Will it be heavy enough so that I can fold it over the edge and using the screen tool bend it in to hold?
I have a 56 vintage.
Old 03-23-2007, 09:46 AM   #13
Home Depot has "solar screening material."
It's thicker than regular screening, so you might have to reduce the size of the spline.
It works great for us, and our customers too.
Old 03-18-2008, 06:15 PM   #14
Vintage Trailer Supply
VintageRV's Avatar
1956 22' Caravanner
Montpelier , Vermont
Screen for Hehr Standard Windows
MediaEtc has a 1956 Airstream.
From 1952 to 1957 Airstream used a model of window made by Hehr called the Standard. It is recognizable because although it uses rectangular glass it looks like it has rounded corners when you stand outside due to the aluminum trim on the outside.
I've attached a photo of this style window.
These windows require steel screen mesh because there is no spline used and the mesh must be crimped around the frame. Aluminum and other soft screens do not hold.
With later windows, you have many more choices, but not with these earlier windows.
$85 for a 100-ft roll is a very good price. I'm guessing you could buy the roll and then sell what you don't need to folks on this list pretty easily.
Steve Hingtgen
WBCCI #1573
VintageRV is offline   Reply With Quote
Computer / Accessories Purchase Advice Needed hex Forum Admin, News and Member Account Info 16 11-20-2003 11:54 PM
Motorhome purchase CBBOB General Motorhome Topics 21 09-10-2003 04:47 PM
What to look for??-trailer purchase Deny Our Community 7 10-30-2002 04:55 PM
Purchase of 73 safari april Our Community 11 09-01-2002 01:33 PM
Refrig pressure gauge. casarodante Refrigerators 5 07-08-2002 11:04 AM
