Old 09-07-2015, 03:25 PM   #1
FUZZY Bug Stuff for window openings
I have a 73 excella 500 replacing the screens and need the fuzzy stuff that goes along the window openings to keep the bugs out.
71excella500 is offline   Reply With Quote
Old 09-07-2015, 03:30 PM   #2
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Try Vintage Trailer Supply - (800) 644-4620
Old 09-07-2015, 03:32 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Maybe here,
Windows and Window Hardware 1969-1974
MICHAEL
Old 11-12-2015, 08:43 PM   #4
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria , British Columbia
InlandRV.com sells it
http://www.inlandrv.com/catalog/prod...roducts_id=321
thesignlady is offline   Reply With Quote
Window fuzzy stuff Silver Threads Windows & Screens 22 08-07-2016 06:24 PM
White fuzzy stuff wall covering Airperson Upholstery, Blinds, Walls & Interior Finishes 4 09-07-2011 06:22 PM
60 Traveler Black Water Tank Openings Motoman Waste Systems, Tanks & Totes 4 10-25-2006 12:13 AM
Mice in through the rear frame openings wacnstac Repairing/Replacing Floor &/or Frame 28 06-16-2006 09:58 AM
Window lift lever fuzzy stuff wacnstac Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 04-20-2006 09:22 AM
