Old 05-30-2010, 01:41 PM   #1
Gator113's Avatar
2007 25' Classic
Port Angeles , Washington
Front window rock guard rubber... are they seals?
I have 3 dark rock guards over the 3 windows on the front of the trailer. Two curved and one flat. On the surface of the edges that face the trailer, there are thick rubber seals-gaskets?..... I don't know what they are called.
Actually, I don't know if they are seals or simply bumpers. I say this because the curved pieces do not seal. These rock guards do not 'appear' to be deformed or tweaked, but at the top and bottom corners they don't even come close to touching the trailer.
My problem is that I don't know what they looked like or how they fit when they were new. Additionally, I live far from any place where I could easily check to see what other trailers look like.
So, should the rubber seal-bumper make contact with the trailer all the way around or does mine sound normal?
Dan
Gator113 is offline   Reply With Quote
Old 05-30-2010, 02:14 PM   #2
TWaugh's Avatar
1969 25' Tradewind
1971 18' Caravel
Images: 8
It's readily available from dealers.
Here is an example from one dealer:
Rockguard Seal 685351 [685351] - $2.29 : ODMRV , Out-of-Doors Mart
The seal follows the edge of the windows all the way around except for the hinge area at the top of the window.
I'm sure someone can post a picture of the three piece unit.
I only have the single piece unit.
You can also watch the install of one on youtube:
Tom
Res nolunt diu male administrari.
WDCU Unit #170
Air #7085
TAC VA-4
WBCCI #2641
VAC
71 Caravel
69 Tradewind
My YouTube Channel
TWaugh is offline   Reply With Quote
Old 05-30-2010, 02:22 PM   #3
_
Originally Posted by Gator113244 View Post
...So, should the rubber seal-bumper make contact with the trailer all the way around or does mine sound normal?...
hi dan
normal
it might be NICE if they sealed in really cold/hot weather but they don't.
bumper/cushion is a better term and unless they've been chewed by sasquatch...
it's unlikely they need replacement at 3 years...
open (or LIFT OFF) the curved sides 1 at a time during calm weather
and clean them, lube with silicone and call it a day.
there is a small ridged PIPING used to keep the smoked guard IN the frame...
i find these need to be TUCKED back in (especially near the corners) 2x a year.
cheers
2air'
Old 05-30-2010, 02:36 PM   #4
Kistler's Avatar
2002 25' Classic
Oro Valley , Arizona
Hi, I/we have the same situation with the front rock guards; we bought our trailer new in 2002 and it was/is that way....gaps.
Leaves, needles, dirt, all get in between where the rubber gasket does not seal with the trailer's windows. I took this to be "normal" and never did complain to Dillons in Apache Junction
In the last couple of years I have had the problem of the rubber round seal coming loose at the corners....like it shrinked. By the by, I am still getting pieces of paper out from between the aluminium frames and the dark plastic.....think the paper was used in transit from Jackson Center to Phoenix, most probably.
I am afraid to bend anything--like the hinges on the corner rock guards--for fear the "fix" will be worse than leaving it alone.
Kistler & Brenda
2002 Classic 25'
2003 Expedition EB 5.4L, AWD, AdvanceTrac Class IV hitch pkg. Reese dual cam/Prodigy
Kistler is offline   Reply With Quote
Old 05-30-2010, 03:27 PM   #5
Gator113's Avatar
2007 25' Classic
Folks, thank you very much.
2Air', I appreciate you looking out for me again and thanks for the extra tips. There's one less 'normal' thing for me to worry about. ;>)
Cheers... as we remember our Fallen brothers and sisters and the reason we remain free.
Dan
Old 05-30-2010, 03:35 PM   #6
Gator113's Avatar
2007 25' Classic
I can sure relate to THAT. The small curved compartment doors at the bottom edge on the road side don't look like they close as 'straight' as I would think they should. So the other day, I started to bend one to make a better fitment when I decided that it probably looked better now, than it would broken off... so I decided to leave them alone. Today we are installing new weather stripping and walking away. LOL
Old 05-30-2010, 03:38 PM   #7
Kistler's Avatar
2002 25' Classic
But it tows well!
Kistler
Old 05-30-2010, 03:52 PM   #8
Gator113's Avatar
2007 25' Classic
But it tows well!
Kistler
And you look cool doing it.
Front Rock Guard DPM All Argosy Trailers 13 05-01-2010 07:58 PM
rock guard/front window evelitalian Rock Guards, Segment & Window Protectors 2 04-21-2008 06:34 PM
Need propane tank cover and front rock guard! cobra93 Rock Guards, Segment & Window Protectors 8 08-11-2006 11:10 PM
What to use to keep window seals/rubber soft. Safari-Rick Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 03-27-2006 07:24 AM
Cheap Front Window Rock Guard Hotlead Windows & Screens 4 06-30-2005 12:31 AM
