Old 08-05-2004, 07:41 AM   #1
JohnG's Avatar
Front Window Question
Has anyone done any work on thier front window, the large one in-between the wing windows.
I have a haze like substance that is between the inner and outer panes. I am considering just taking that one to the glass installer locally and having the glass removed and replaced with a new single pane. Its flat glass so I don't know if there would be a problem.
Mine is a 75 and just wanted to know if anyone else has experienced this and what the solution was.
Just adding my 2˘ worth
John G
___________________________
1975 31ft Sovereign International
........Rear Bath Double Bed Model
Tow Vehicle:1999 GMC Serria SLE Classic 1500 5.7Ltr
System: Jordon 2020 Ultima Brake Controller
Hook-Up: Equalizing Hitch and Sway Bar
JohnG is offline   Reply With Quote
Old 08-05-2004, 11:20 AM   #2
JohnG's Avatar
Asking again!
John G
Old 08-05-2004, 03:58 PM   #3
JohnG's Avatar
Asking again?
Well, if you don't have an answer on the top ost then how about this, does AS place a solid window there now or is it still a double pane window?
There isn't to much aboutthis window that I could find in the forum anywhere. If you know of a thread that discusses this please point it out.
John G
Old 08-05-2004, 09:39 PM   #4
JohnG's Avatar
Bumped back up and hoping for some insight!
John G
Old 08-06-2004, 06:47 AM   #5
qqq
qqq's Avatar
Try searching with "Vista view" as they have the same problems as your front window.
Ron
qqq is offline   Reply With Quote
Old 08-06-2004, 10:02 AM   #6
JohnG
Just remove the inner pane of glass or plastic as the case may be.
You can then scrape off the mylar film that is on the inside, of the outside glass.
There would be no need to replace the outer glass.
A glass shop probably could not be of much help to you.
1975 Argosy front window Happycampers Windows & Screens 9 11-03-2005 07:51 PM
1974 Excella front window docu post john hd 1973-1974 Excella 500 22 08-06-2004 01:53 PM
front window adjustment jackt Windows & Screens 2 03-18-2004 05:36 AM
Leaking Front Window '63 Safari srgntpepper Windows & Screens 1 08-16-2003 04:25 PM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 06:04 PM
