Old 12-22-2012, 03:12 PM   #1
1973 31' Excella 500
Fayetteville , Arkansas
Front window handle removal
Im trying to remove the front window on my 73' Excella. Can anybody tell me the best way to remove the raise/lower handles on the window? I understand its hinged on the top but due to the interior handles on the bar I can't get the handles through the metal thing that allows you to prop the window open.
ID:	175041   Click image for larger version
ID:	175043   Click image for larger version
InHogHeaven is offline   Reply With Quote
Old 01-06-2013, 09:42 AM   #2
It turns out there was a nut and bolt holding it together. The space to access the head had been packed full of crud and I couldn't see either end of the bolt. After about 20 minutes of painstakingly digging out tiny amounts of dirt the bolt head was revealed. Anyway, I hope this helps someone else out on down the line.
Old 01-27-2017, 10:59 AM   #3
1981 31' Excella II
Round rock , Texas
Having the same problem
I still have the wooden handles on mine-- How do I get them off? I figure I should hold the nut still, but I can't get to it because of the wood.
Any help you can give would be greatly appreciated.
sphinxatuf1 is offline   Reply With Quote
