Front Pano tinted RG section is ....
well, it has a crack in it. 1 1/2 inches and currently static as the trailer isn't moving. It happened during the ROUGH return tow from AZ. It is the front side window-the wing to match the others for the FULL Effect.
So, on to the question. Where do I get such a 'window' replaced? The replament is also lexan. it's just Lexan (I think!) and has to be bent to allow it to be used.That bending would likely have to be with the TT present since I know that there are numerous little things that can just drive you nuts.
I would like to do this myself if there is ANY way that I could. I think that this sort of thing helps to bond yourselves with this Aluminum. My .02 cents.
Any thoughts on where to go and, oh the cost! Send me an PM with the merchant info and the cost element in there as well.
THanks for all thoughts and positive comments. ooking forward to one and all!
Axel
