Old 07-14-2006, 06:05 AM   #1
tinsltootsie's Avatar
corner window replacement
Well, we just got back from a great stay at the beach, and noticed about an hour into our ride home that the left front window on our 74 overlander looked shattered. We were hoping it was the reflection on the old tinting, but it was broken. !!! Any advice on replacement and purchase info? Where, and how? I will try Colaw's later this morning and then go on from there. Thanks for any info.
It's the rivets!!!!!
tinsltootsie is offline   Reply With Quote
Old 07-14-2006, 06:14 AM   #2
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
Do you have the twin pane windows? If so and only one pane broke all you really need to do is clean up the broken glass. The single pane is what you will get for a replacement and what you have will serve you for many years.
Good luck to you.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 07-14-2006, 06:17 AM   #3
front corner window replacement
Hi! I may have posted to a wrong thread, so will post again. Our window on our 74 Overlander shattered on the drive home from a trip. We have no shield, so we are not sure if it were a rock or just impact of travel. Anyone have experience in replacing them, and where I might find one or what I should/ could do? I will try Colaw's later today. Thanks!
Old 07-14-2006, 06:21 AM   #4
Hmmm. Thanks! It was dark when we got in and I didn't look from the inside. The outside was bad enough! My fingers are crossed that only one shattered. It is a double paned thermal.
Old 07-14-2006, 07:22 AM   #5
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Broken corner window
If you have no luck at Colaws let me know. I have access to some windows....only for those who need them....not resellers.
Old 07-14-2006, 01:04 PM   #6
Thank you! It seems to be only the outside. I am going back later to finish the cleanup and then plan to get the broken glass out. Hopefully that will go smoothly.
Old 07-14-2006, 08:21 PM   #7
1978 31' Excella 500
Goose Creek , South Carolina
I would replace the window if the outer is broken, you would have a hard time trying to get a good seal. Removing the inner pane when the seal between the two pieces of glass fail is a different story (at least to my knowlege). If you check with www.out-of-doorsmart.com they often have NOS or salvaged glass, they also have single pane replacements.
Holzarbeiter is offline   Reply With Quote
Water heater replacement Craig Water Heaters, Filters & Pumps 36 12-18-2014 09:13 AM
Vent Covers front two tmeagle1 Roof Vents, Skylights & Fans 1 05-15-2004 08:17 AM
Minuet Front Window Rock Guards overlander64 All Argosy Trailers 54 12-01-2003 09:13 PM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 06:04 PM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 12:40 PM
