Old 10-12-2004, 11:32 PM   #1
5 rivets, 1 loose screw
Rog0525's Avatar
1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
Question Frameless window size on '66 Ambassador
Rambo's rear window pane was broken out by the PO, possibly as a an escape hatch in case of federal intrusion on the compound.
Is this something I cn have fabricated at an auto glass shop and if so, I need the dimensions.
Is plexiglass ok? This is a frameless window so I am concerned about how to properly secure it in the upper track.
Just to be clear on the styling of this coach, I am attaching a pic in it's natural habitat.
Name:	Rambo woods.jpg
Rog
May you camp where wind won’t hit you, where snakes won’t bite and bears won’t git you.
Rog0525 is offline   Reply With Quote
Old 10-13-2004, 04:51 AM   #2
Window size
Corning Window size is 39" wide x 20 1/2" tall, I think I used plain silicone, seems like it was a tight fit also. Toby
Toby is offline   Reply With Quote
Old 10-13-2004, 06:33 AM   #3
rluhr's Avatar
1968 17' Caravel
2005 30' Safari
Somewhere , roaming America
Rog, don't use Plexiglass because it yellows and scratches easily. For a few bucks more you can pick up a sheet of Lexan, Acrylite, or other brands, cut to size, from your local window glass shop. Those types of plastic are much tougher. Inland RV sells some with an anti-scratch coating, pre-cut to size. Home Depot stocks Lexan, but you'll need to cut it yourself.
Silicone or double-sided tape are fine to secure it in the hinge clamp. When you replace the window you'll want the metal edges found on the later 60s models to hide the cut edge of the plastic. Inland RV sells those, too, or you can try salvage. Secure that to the plastic with a few dabs of silicone as well.
Former full-timer | AIRSTREAM LIFE magazine | Tour of America (old blog) | Man In The Maze (current blog)
rluhr is offline   Reply With Quote
Open your frameless windows wide? TomW Windows & Screens 17 08-23-2004 08:14 PM
1974 Excella front window docu post john hd 1973-1974 Excella 500 22 08-06-2004 01:53 PM
Bambi 19' rear window screen yukionna 1997 - 2004 Bambi 2 05-26-2004 08:45 PM
Report of window replacement in 1977 Minuet 6.0 kenny All Argosy Trailers 2 08-27-2003 07:11 AM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 06:04 PM
