Originally Posted by jmpratt
Andy,
I assume the frameless windows will fit even though it originally had aluminum extrusions framing the glass?
Nope.
You would receive a glass and sash. The sash is the metal part that surrounds the glass.
BUT..................what you will have to do, is remove the hinge from the old sash and glass and install it on the new window.
WHY??????
Because Airstream picked a goofy hinge for the 69 production year and the 70 windows, while being the same size, use a different hinge.
If you attempt to use the replacment window hinge, you will snap off every rivet that holds the hinge to the sash.
I have gripped about that to Airstream for only 4 decades, and the answer is always the same. CHANGE THE HINGE.
Sorry, but that's the way it is.
