Old 03-03-2010, 05:39 PM   #1
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
Emergency Exit Window Operation
In my 1993 Land Yacht Motorhome MH, the owner's manual says to test periodically the Emergency Exit window by removing it. I have been unable (short of breaking the window) to remove it. Are there any other instructions or techniques for removing this window aside from 'pulling red handle? I believe its a HEHR brand sliding glass single pane window.
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
http://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
Old 03-03-2010, 05:59 PM   #2
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
On my 84 310 MH the emergency exit is the rear window (other end from the windshield). You remove it by pulling the red handle, then swing the bottom outward until the hinge at the top disengages. Its a good idea to be prepared for this before it happens.
Don't know if the 93 LY is similar.
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 03-03-2010, 07:16 PM   #3
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
guy99, mines located on the side. From the outside there isn't any hinge or different window design to show this as a special window. In fact it doesn't look any different than other side window in bedroom ,thats what got me puzzled as to how it comes out.
Old 03-03-2010, 07:20 PM   #4
guy99's Avatar
Images: 16
Sorry I wasn't any help.
Old 03-03-2010, 11:23 PM   #5
VinFan
vinfan's Avatar
1984 27' Airstream 270
First capital , Ohio
rear window
Guy99,
I have a 1984 270 Excella with that rear emergency exit also.
I have not tried to open it , but it sounds like something I should test.
Do you have to reseal it in any way after you test it? Mine seems very
tightly sealed and isn't leaking.
Thanks in advance for your info.
Margaret
vinfan is offline   Reply With Quote
Old 03-04-2010, 04:51 AM   #6
firedog's Avatar
1992 29' Excella
JOY IN , Arizona
if it isn't broke don't fix it.
wbcci ,#3510 NEU & 4cu http://fire1.smugmug.com
firedog is offline   Reply With Quote
Old 03-04-2010, 07:31 AM   #7
guy99's Avatar
Images: 16
Originally Posted by vinfan View Post
Guy99,
Margaret
I haven't had any sealing problem. To operate mine I just release the red latch and open the window by pushing out at the bottom. When it has been opened far enough you lift slightly at the top and the hinge comes apart and the entire rear window come off. If you decide to try this BE PREPARED, the window is kind of heavy.
YMMV
Old 03-04-2010, 10:33 AM   #8
VinFan
vinfan's Avatar
Guy99,
You did address my next thought. how heavy is the window. I quess in the case of emergency you just let go and get out.
Margaret
Old 03-04-2010, 10:54 AM   #9
guy99's Avatar
Images: 16
The weight is not extreme, but it is a fairly large piece of glass.
Old 03-05-2010, 11:42 AM   #10
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
Follow up on Emergency Exit window on 1993 LY motorhome - checked with Hehr window manufacturer, with rear side sliding windows in bedroom, their sliding window is large enough to accomodate an exit when slid open. Even though only one side is marked with red handle as an emergency exit, both side windows can be used. According to law only 2 exits are needed, front door and one window exit. There is no removal of the glass with sliding windows on these models. My confusion on this issue was that the owner manual states "The escape window which is the roadside rear window is opened by pulling in and down on the red release bar. Push out on the glass and it will swing clear."
Thank you for your various replies.
Old 03-05-2010, 02:39 PM   #11
2008 16' Safari
Destrehan , Louisiana
The first time I opened my emergency exit window it took a good bit of force to get it open. That's why the book says to do it peridicaly. They stick after about a year or so they need to be exercised to break the seal. It's better to practice before an emergency.
dlb435 is offline   Reply With Quote
Emergency exit window reddogfox 2008 Safari SE 10 07-18-2016 04:33 PM
Rear Exit Window willyd Windows & Screens 2 07-14-2008 01:52 PM
Furnace with top exit JerryK Furnaces, Heaters, Fireplaces & Air Conditioning 2 11-27-2004 10:14 PM
Keeping the exit clear! Cracker Our Community 4 12-08-2003 10:11 AM
Exhaust pipes to exit left but where? Astrodokk Airstream Motorhome Forums 6 10-18-2003 08:21 AM
