Old 08-15-2015, 11:26 AM   #1
2009 19' Flying Cloud
Iowa City , Iowa
Emergency exit window
Hello Everyone,
We just bought our first Airstream! I noticed the rear window, which is also the emergency exit, does not have supports to hold the glass open. All of the other operable windows have supports. Is this normal for a 2009 19' Flying Cloud?
Many thanks,
ericdean is offline   Reply With Quote
Old 08-15-2015, 12:42 PM   #2
Originally Posted by ericdean View Post
Hello Everyone,
Many thanks,
No.
Supports can easily be added.
Old 08-15-2015, 01:43 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Yes,
MICHAEL
Old 08-15-2015, 01:45 PM   #4
dznf0g's Avatar
Oswego , Illinois
I wonder why in some models and not others? Mine has support rods.....
-Rich-
Old 08-15-2015, 02:04 PM   #5
AWCHIEF's Avatar
Images: 33
Beer can work very well as a hold open or the most handy stick.
MICHAEL
Old 08-15-2015, 02:21 PM   #6
knunut's Avatar
2007 20' Safari
2016 26' Flying Cloud
Chgo. N.W. Burb's , Illinois
Its a Joke in our 20 . You would have to crawl over the sink and faucet ! NO way am i going to make it. I figure in anything less than 25 Ft. Your going out the main door !! Would be better busting out the dinette window with the Fire extinguisher .
knunut is offline   Reply With Quote
Old 08-15-2015, 03:54 PM   #7
robert claus's Avatar
2000 19' Bambi
mt. Prospect , Illinois
If it is like my 19', it does not have a screen, so it's limited in use as a opening window. I tried that, and even fabricated a screen system, but gave up on it as it could not be made insect proof while providing access to the closing clamps. You don't want to risk deforming or damaging the gasket, either, or you'll have a leak to contend with.
No WD, but a great DW!
robert claus is offline   Reply With Quote
Old 08-15-2015, 04:22 PM   #8
dznf0g's Avatar
Oswego , Illinois
Mine is equipped with a screen with a rip cord for quick exit.
-Rich-
Old 08-15-2015, 04:41 PM   #9
Streamliner
Markj55's Avatar
2006 19' Safari SE
Santee , California
I believe they started doing the 19s with the rip cord in 2005 which is my model. It must be some kind of law or why would AS put an emergency exit in at all, let alone in such lame places. And really, if it was to escape anything faster than a turtle spider (made up) you'd be doomed anyway! Especially in a 19' or 20'..... I'd love a regular window!
Speaking of windows, the kitchens areas should all have opening windows. Maybe then you wouldn't have to disconnect the almost worthless smoke detector. Just sayin.
Mark,
The path not taken is the one I'm on...
Mj: "I'm on the road again"
Markj55 is offline   Reply With Quote
Old 08-15-2015, 05:54 PM   #10
AWCHIEF's Avatar
Images: 33
No rip cord or screen in my 2006 Safari 23. I might be able to make it thru the opening if death was the only option but not holding my breath. Not sure if it is actual law but it is required for RVIA code certification that there must be a rear exit.
MICHAEL
Old 08-15-2015, 07:14 PM   #11
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Originally Posted by Inland RV Center, In View Post
No.
Can you tell us what parts would be needed, for supports and a screen. My 2000 Safari six sleeper has an emergency exit in the rear. I would really like to make it operable with a screen.
Alan
Old 08-15-2015, 07:31 PM   #12
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Doesn't the entire window come out of the frame? A question of window width? Bigger than I thought it would be on my vintage kin once removed.
I've had to climb in and out of mine a couple of times on a past trailer. I found it handy to know whether feet or head first on the way out. I do know I don't want to land on the glass.
On each of three same brand trailers there has been quite a bit of dust turned to crud accumulation between window and frame. Pretty sure no PO had ever removed and cleaned. Operation was easier as a result on each trailer.
I like to think we'd get out of our TT type faster than with SOB. Twice I have timed fires in fiberglass bodied semi-tractors and it was five minutes to consumption in wind. Once the fire reaches the shell it's pretty much over.
Old 08-15-2015, 07:45 PM   #13
AWCHIEF's Avatar
Images: 33
My rear window hinges at the top. Two latches at the bottom. I can fit thru it but the landing will not be pretty. Thankfully no Olympic scoring in survival.
MICHAEL
Old 08-15-2015, 08:42 PM   #14
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
The detail differences of AS trailers often aren't known to me. For others as well, is this common that the escape window swings versus falls free? A change from years past?
As to dignity, the first time I had to use it was in cinched bathrobe with all else hanging free. Jalousie window open and my cutting screen to access levers.
Emergency exit window reddogfox 2008 Safari SE 10 07-18-2016 04:33 PM
Clipper, Emergency Exit, Land Yacht, Emergency Ladder masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 9 03-05-2015 10:34 PM
Emergency Exit Window Conversion? jonplayers Windows, Doors, Locks & Vents 16 01-16-2015 01:12 PM
"Exit Now" or "Next Exit" which is better hhendrix On The Road... 2 05-23-2010 03:07 PM
Emergency Exit Window Operation gloran Windows & Screens 10 03-05-2010 02:39 PM
