Old 08-23-2008, 08:35 AM   #1
1967 20' Globetrotter
Houston , Texas
E-ring removal
I need to replace a window; however, I cannot figure out how to remove the e-ring. I've tried using retaining ring pliers without any luck although I'm not entirely certain what I'm supposed to be doing with them. I must be doing something wrong or missing something.
tphillips is offline   Reply With Quote
Old 08-23-2008, 09:52 AM   #2
lewster's Avatar
Naples, FL , Hood River, OR
I usually use a flat blade screwdriver on 'e-clips', and the generally pop right off. A pair of wide jaw pliers like linemans pliers will get them back in place easily.
Old 08-23-2008, 01:20 PM   #3
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
What year do you have - it's not shown in your profile information. Do you have actual e rings with retaining ring holes in them - or maybe - the dreaded flat snap ring....
Old 08-23-2008, 03:05 PM   #4
Houston , Texas
I have a '67 Globetrotter. I'm pretty sure it's an e-ring, at least that's what it is called on the vintage rv instruction sheet for window replacement.
snap ring removal gary Windows & Screens 12 07-04-2013 12:42 PM
Wax ring???? retrocats Sinks, Showers & Toilets 20 04-24-2007 08:02 PM
Tossing my hat in the ring Alden Miller 1981 - 1983 Excella 9 07-01-2005 10:24 AM
Bayonet ring repair davidz71 Waste Systems, Tanks & Totes 0 01-02-2004 11:06 PM
Table ring Lee Pace Cabinets, Counter Tops & Furnishings 5 09-14-2003 11:34 AM
