Old 12-17-2007, 06:32 AM   #15
Baltimore , Maryland
Originally Posted by ZoominC6
Between the "A" and the "T" Sorry, I just couldn't resist.
I told you I am slow... I just got it. Must have been that Reagan Zap at the bottom of your tag that kept me from understanding... Remember his wife's campaign? "just say no"... that was a huge success....
Old 12-17-2007, 06:53 AM   #16
1958 26' Overlander
Lander , Wyoming
Frank, Thanks for the praises. Glad I could help out a fellow airstreamer. Your drip cap is on its way! Great job with your renovation so far. Ed
n2batr is offline   Reply With Quote
Old 12-17-2007, 09:44 AM   #17
byamcaravanner's Avatar
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha , Wisconsin
Originally Posted by Aerowood
NTP is a little to general can you narrow down the search.
From the linked image properties I came up with THIS
If you search "drip cap" you will find that they have lengths in increments of 2-4 inches from 20" to 86"
Steve & the crew
'70 Ambassador International Twin
'63 19' Globetrotter TAC WI-1
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 12-17-2007, 10:39 AM   #18
Very true.
But the fact is, "no one" has a new 46 inch drip cap.
A larger one can be installed, but some owners insist on the 46 inch drip cap.
It won't happen.
Old 12-17-2007, 10:47 AM   #19
Images: 59
Hmmmm. . . .
The NTP website only has listed the 44" and 48". But there is a missing part number in the sequence between the two sizes. I wonder if you ordered P/N 20-0767 would they send you a 46" drip cap?
Old 12-17-2007, 11:22 AM   #20
Originally Posted by markdoane
Hmmmm. . . .
Nope.
NTP does not have any such stock number.
Old 12-17-2007, 07:19 PM   #21
But a 46" one does exist. I was on the front of my overlander. It was severely damaged by huge screws used to install a rock guard. I am sure other early 60 's overlanders had it too. No one makes them now, that is right. But Ed had one. Big karma to Ed for that...
Help needed with A/C drip nickcrowhurst Furnaces, Heaters, Fireplaces & Air Conditioning 14 12-06-2006 08:27 AM
Drip, Drip and Crack jcanavera Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 09-06-2006 08:17 AM
AC drip,drip,drip,drip,drip Canuks Furnaces, Heaters, Fireplaces & Air Conditioning 6 06-02-2006 02:05 PM
drip caps chalcedon Exterior Restoration Forum 1 04-30-2006 11:17 AM
AC drip hose Tin Hut Furnaces, Heaters, Fireplaces & Air Conditioning 2 10-20-2003 08:30 AM
