Old 03-27-2007, 02:54 PM   #1
pinkflamingoes's Avatar
1967 24' Tradewind
Alameda , California
Images: 38
Send a message via AIM to pinkflamingoes Send a message via Yahoo to pinkflamingoes
drilling Lexan?
Is it possible to drill holes in Lexan without ruining the window?
I'm just brainstorming here on something.
"Let's look Death in the face and say, 'Whatever man.'"
~ Hurley
ingrid
1967 24' Tradewind #19104 ~ Forums #4449
pinkflamingoes is offline   Reply With Quote
Old 03-27-2007, 03:16 PM   #2
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
Hmm, I know you can cut through it with an abrasive saw...I don't see why it wouldn't drill. But you can't practice on mine!!
Dave
Fyrzowt is offline   Reply With Quote
Old 03-27-2007, 03:17 PM   #3
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
I know it's easy to cut with a jig saw... so it's pretty tough stuff.
It may take a special plastics drill bit to keep it from cracking that you can get at Tap Plastics.
Your lucky since there is one in Pleasant Hill, CA. I was just there yesterday and saw them.
If you have a scrape peice just give it a try. Or you can use a flat paddle type drill bit normally for boring large holes in wood. I use those on laminate as well since it cuts the outside of the hole at the same time as the inside and keeps it from cracking.
-Tim
theVAP - Airstream Podcast
Old 03-27-2007, 03:35 PM   #4
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
I Had no Problem Drilling Lexan...
but maybe I didn't know I wasn't supposed to be able to do it.
Actually, it behaves nicely if you drill at a slow to moderate speed. At higher speeds, the Lexan melts and gums up the drill bit.
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 03-27-2007, 03:42 PM   #5
Fyrzowt's Avatar
2000 25' Safari
Images: 8
Do you want to share the brainstorm? You have my curiosity up...
Dave
Old 03-27-2007, 04:06 PM   #6
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Drill it, cut it, shear it, bend it, just like a soft piece of aluminum. No special drill bit needed. High speed low pressure.
Old 03-27-2007, 06:39 PM   #7
bhayden's Avatar
1978 24' Argosy 24
Woodinville , Washington
I'd second the moderate speed (depending on hole dia) so you don't melt the plastic. I'd start with a small pilot hole, something you could do with a variable speed Dremel tool. A hole saw works for larger holes. If it's Lexan (brand name for polycarbonate) you should be golden. If it's acrylic then all bets are off. That stuff has a nasty tendancy to crack when you try to drill it. It can be done if you're careful but it's a bit more hit and miss than polycarbonate.
-Bernie
bhayden is offline   Reply With Quote
Old 03-28-2007, 06:15 AM   #8
lewster's Avatar
Naples, FL , Hood River, OR
You can do just about anything that you want to LEXAN. I built a complete set of hurricane storm windows out of the stuff a couple of years ago. Glad I had them when Wilma hit!!!!!
Anyway, I used a regular drill bit at high speed with very light pressure or the driill will bog down. The holes were very clean and precise!
Cut it with a circular saw and carbide blade. Be careful with the surface though. As strong as the stuff is, it scratches VERY easily!!!
Old 03-28-2007, 10:41 AM   #9
There are different types of Lexan.
The Lexan windows, for the 66-68 trailers, that we provide, are coated on both sides. it's called AR-2.
You can scrub it with medium steel wool, and not scratch it.
Of course, that adds to the price, considerably.
Old 03-28-2007, 12:37 PM   #10
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Lexan Polycarbonate is very tough but is sensitive to certain chemicals and solvents. This is particularly so if it has been stressed or machined without annealing it. That is why they do not allow you to modify Lexan motorcycle or snowmobile helmets. If you do want to drill a hole in Lexan use a very sharpe drill and move slowly to creat a uniform chip. Drilling a pilot hole followed by another drill is preferred. Anneal the hole afterwards by using a hot air gun they use to strip paint or shink heat shrink tubing. Raise the temperature of the plastic to about 350 F and keep it there for 10 mins. You can verify the sheet has been properly annealed by viewing it with polarized light from one side and polaroid glasses from the other side. Properly annealed material will have no birefringence.(colored rainbows)
Old 03-28-2007, 02:38 PM   #11
1967 24' Tradewind
Images: 38
awesome
If I decide to take on my top-secret mission, I shall do as instructed. I have a heat gun. Thanks all!
~ Hurley
ingrid
Old 03-28-2007, 03:30 PM   #12
bhayden's Avatar
1978 24' Argosy 24
Wow, until I joined this forum I thought everything I really needed to know I'd learned in Kindergarten
Will the 350 deg make the plastic soft enough to smooth out sharp edges and removed any burrs or feathering?
-Bernie
Old 03-28-2007, 05:15 PM   #13
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
I don't know about you guys but we shot my .45 into a sheet of Lexan and all it did was leave a bif dimple and fogged area!
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 03-28-2007, 07:46 PM   #14
lewster's Avatar
Try hitting it with a sledge hammer and see what happens (or doesn't)
SF Bay Area - Need Help w/ Lexan (polycarbonate) source Mookie Windows & Screens 3 03-19-2007 09:56 AM
drilling out rivets dhe9 Ribs, Skins & Rivets 9 02-08-2006 12:07 AM
Drilling out rivets MarkR Ribs, Skins & Rivets 5 06-12-2005 09:54 AM
Trouble Drilling to Install Anti Sway Cams DEO Hitches, Couplers & Balls 21 02-26-2004 05:15 AM
Drilling out rivets... Andy R Ribs, Skins & Rivets 2 04-13-2002 03:02 PM
