[quote=frozen chosen]We have an '04 16' which has no factory shade on the door. Has anyone come up with a good way to block the light? quote]
I use a standard Home Depot roller blind, cut to your required length at the store for just a few dollars. It is slightly wider than the glass, and is fitted between the inner and outer skins of the door. You will probably need to remove the top half of the inner skin of the door, drilling out the rivets with a 1/8th bit. Fitting the brackets may require some ingenuity. If there is no handy inner strength member, you may need to fit the brackets to the inner face of the inner skin.
Nick
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
