Old 04-28-2009, 05:59 PM   #1
Y2k_Knight's Avatar
Barstow , California
Send a message via Skype™ to Y2k_Knight
Red face do I really need to replace the windows? all of them??
I'm looking at a 1973 Sovereign, it's really nice but there is a problem. T the sunscreen coating which is inside the thermopane is deteriorated. The owner told me other people have just turned around and walked away when they saw it even thought it isn't that bad (according to him).
Is this a really bad problem? and how to I fix it? replace all the affected windows? I would have some used windows to sell but I'm sure that the cost difference would still be wide.
I appreciate your input.
Y2k_Knight is offline   Reply With Quote
Old 04-28-2009, 07:11 PM   #2
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Some of those windows will come apart for cleaning. I helped a friend take his out and the glass separates. His was a 73 model.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 05-02-2009, 01:45 PM   #3
Sue
1971 29' Ambassador
Wilmer , Alabama
Cool Window nightmare
I am restoring a 71 - I am attempting to replace all the window seals including the seal between the frame and the glass (found a wed site that has a seal that works great) how do you get the frame apart? short of breaking the glass and starting over???
sburgess is offline   Reply With Quote
Old 05-02-2009, 05:19 PM   #4
drag'nwagon's Avatar
1970 23' Safari
1956 26' Cruiser Overlander
Lambertville , Michigan
you may be lucky enough to have the split ring on the inside of the windows. My 74 has the split ring and is pretty easy to remove the ring, take out the inside piece of plexi and then scrape off the old film and re-install. I will say that getting the retaining ring back in can take a little doing.
Dave
TAC# MI-1
Operation "Save Rudy" Strike Team (charter member)
Yes, I am still working on it.
drag'nwagon is offline   Reply With Quote
Old 05-02-2009, 05:30 PM   #5
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
My 75 has the inner split ring with the plexi and it looks really ugly. What did you grab the inner ring with to remove it? It is pretty flat.
Richard
Old 05-02-2009, 05:59 PM   #6
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
It's a very common problem that doesn't hurt the window.
I don't think 73 does not has the split ring. There are 3 alternatives. #1 take the window out, take the frame apart clean the glass and install new butyl gasket. Don't count on being able to reuse the frame gasket and new gaskets I don't think are available. You can substitute vulkem. #2 Carefully break the inner pane. #3 live with it.
Zeppelenum and I put up threads on the rebuild process a couple of years ago. Do a search. Rebuilding the window is very time intensive. New windows are available. Windows from 70 to mid sixties are to some extent interchangeable.
Old 05-03-2009, 09:49 AM   #7
1970 23' Safari
Richard,
I used a flat screwdriver to pry up a bit and then grab with needle-nose, it is frustrating, but you will get it. putting it back in is worse.
Dave
TAC# MI-1
replace gasket on wing windows - 75 argosy bamaargosy28 Windows & Screens 0 04-11-2009 02:51 PM
replace AC? roguebrun Furnaces, Heaters, Fireplaces & Air Conditioning 6 10-29-2008 06:09 PM
'Nice' Windows vs. 'Cheap' Windows on New Units AZ-JH Windows & Screens 10 05-08-2008 05:27 PM
Replace/fix cruddy fixed windows? 26.982 amu Windows & Screens 3 01-01-2007 08:57 AM
Windows-probs, Linux more prbs...back to Windows Kistler Off Topic Forum 13 11-04-2004 09:19 AM
