Old 10-08-2006, 06:05 PM   #1
pahrump , Nevada
davencece
double pane window restor:
How do I separate the double paned windows for restore? Gasket material in one has worked into space between, looks like doo-doo, and window tint film has bubbled up in others. Know that when reassemble will need to charge with nitrogen and seal somehow. Anyone know the procedure and willing to share?
Dave n Cece
davencece is offline   Reply With Quote
Old 10-28-2006, 06:51 PM   #2
1982 34' Limited
Chatham , Ontario
good question! How do you seperate window panes?
I have exactly the same problem. I notice that you have gotten no response. Is this the big question of the year that nobody has the answer to? Have you learned anything on your own on this issue since you posted this question? If so can you let me know?
frank n'shar is offline   Reply With Quote
Old 10-28-2006, 07:40 PM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
Welcome to the forums, one and all! Haven't had this problem myself but it is a frequent enough thread. Searching on 'double paned' I found the Fixing Foggy Fenestration thread -- just one of many times it has been brought up. Proceed carefully. I'd suggest waiting for somebody experienced to guide you through it. Digital pics of window type and location would help in the meantime.
5 meter Langford Nahanni
davencece davencece Member Introductions 3 09-26-2006 10:41 AM
