Old 05-15-2009, 06:43 AM   #1
1995 30' Cutter Bus LE
Talco , Texas
Cutter window leaks
Hello to all, the window in my bedroom leaks. I thought the problem was a leak on the outside but it is on the inside. Water is filling up in the pane glass channel and spilling over onto the interior wall. I noticed two slits on the underside of each window on the outside frame of the window unit and was wondering if these might be drain slots for the windows? Could the problem be as simple as a plugged drain? I have removed the window and replaced the warped wall on the interior. I had previously sealed around the outside of the window with a good silicone sealant so I am sure the leak is not around the frame. Can anybody advise on the window itself and what I might try to do with it. Can I disassemble the window and clean it? Any help would be appreciated. Thank you for your time, Jack
ic2jack5648 is offline   Reply With Quote
Old 05-15-2009, 06:59 AM   #2
bullydogsmom's Avatar
1972 25' Tradewind
old mystic , Connecticut
You shouldn't use silicone on an Airstream. Vulcum or Trempro is what you should use. What year is you AS? Maybe if you post the year, someone with the same year can answer your question about the drain holes, we have a 72 and I don't see any drain holes in the frames.
Annette
bullydogsmom is offline   Reply With Quote
Cutter, Defective Window Seals paulnmargie Windows & Screens 1 01-11-2011 10:05 PM
Window Leaks(?) in 76 Argosy Toby Briggs Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 08-13-2007 03:04 PM
front window water leaks vickeelee 1981 - 1983 Excella 3 08-31-2006 07:48 AM
Window leaks, where to start? wacnstac Leaks - Weatherstrips, Gaskets, Caulks & Sealants 26 04-10-2006 12:31 PM
Window Leaks tincanholiday Windows & Screens 3 01-11-2004 02:36 PM
