Old 11-10-2014, 12:11 AM   #1
Glendale , California
Curtis Wright screen replacement
I have been working on my 1948 Curtis Wright for several months and finally had a chance to work on the screens. I wanted to replace the screens without having to pull all of the rivets and remove all of the windows. I finally figured out an excellent way to do it. I made frames from aluminum bar (1/2" wide x 1/8" thick). I cut these bars into lengths that, when put inside the window frame, they fit just around the original metal groove where the original screen was splined into. I had to trim 1/8" off of the width of the top bars so that it had enough room to fit between the top of the window frame and the spline metal. I then placed the bars into a rectangle and riveted them together using 1/8" rivets. I smashed the rivets flat with a hammer. I put 5 minute epoxy on one side of the frame and placed galvanized heavy duty screen material over the frame. I weighted down the screen with 2x4s inside and out for a good gluing. After the epoxy had cured, I trimmed the screen excess off and put in the screen. I installed the window closing hardware and put the interior trim pieces on. The benefit to this replacement is that, if I need to replace a screen in the future, all I need to do is remove the interior trim pieces, pull the screen
with its frame out as one piece, cut the screen out and glue another one in its place. I cannot tell that the screen has been replaced in this fashion. It looks original and doesn't show inside or out. I glued D shaped weather strip from Vintage Trailer supply on the frame on the outside of the window. Very clean install. Water tight and very nice! Here are a few pictures of the screens. Chris
ID:	226163   Click image for larger version
ID:	226165   Click image for larger version
chris hart is offline   Reply With Quote
Old 11-11-2014, 11:01 AM   #2
1950 18' Clipper
Highland , Utah
I just replaced the windows in my 1950 Curtis Wright Clipper. I bought the screen tool and material from VTS but have not tackled replacing it yet. Thanks for the pics and suggestion on how to replace the screen.
jrjackson is offline   Reply With Quote
Old 11-11-2014, 09:07 PM   #3
I looked at the original screen install and determined that the whole window had to be removed (drill out rivets from outside), spline the new screen in, and install a new gasket reinstalling the window. I don't think you can reach around the spline channel to install the new screen even when you take the trim off around the windows. It sure seemed like a whole lot of work. Making the screens the way I did, one can easily replace the screen in the future without too much hassle. The D seal on the outside works great.
Old 09-05-2015, 01:20 PM   #4
dpaul0265's Avatar
1947 22' Liner
Durham , North Carolina
So if I understand correctly did you cut out the old screens and then insert the new framed ones place?
dpaul0265 is offline   Reply With Quote
Old 09-06-2015, 11:15 PM   #5
Yes. The old screens are just attached using a spline tool that jams the screen into the frame. No spline. I removed the screen and left the frame there in it's original state. The screen and frame I made fits in like a glove. No screws needed to attach it since the frame trim inside covers the new screen and frame holding it in place. Easy to remove if damaged.
Curtis Wright Alien eyes window replacement chris hart Windows & Screens 2 11-24-2015 11:57 PM
'53 Clipper and '49 Curtis Wright.. Clipper JayDigger Vintage Kin 13 02-24-2015 08:21 AM
Curtis Wright screen repair chris hart Vintage Kin 0 02-22-2014 09:51 PM
Curtis-Wright -1936 truckasaurus Airstream Trailer Forums 5 07-05-2005 08:41 AM
