Old 07-05-2014, 09:17 AM   #1
Glendale , California
Curtis Wright Alien eyes window replacement
Howdy all. My Curtis Wright trailer restoration is going well and, as usual, much longer than I had anticipated! I have a window question regarding the front and back windows. One thing that I want to figure out before I attempt it is, how to put the alien eye windows in. John (PLVMB) installed his using the original idea of putting a frame of plywood inside the aluminum channel that goes around the edge of the window area on the body. I was thinking of doing that and using Sikaflex to slather the wood in order to make a nice seal. The only problem with that is that, if I want to remove the window at a later time and replace it, it would be impossible to remove the channel without damaging it. I want to use the original channel but want to use some other method to attach it to the body of the trailer. What have you guys done? Is there a rubber gasket that I can use instead? When removing and replacing the windows, is it necessary to remove the channel from the body? If I can permanently put the channel on the body, I would permanently install it with Sikaflex. Not real sure how to install the window so that it doesn't leak. Between the channel and the window, what gasket should I use? I would want to use something temporary so that I could replace a window later if necessary. Thanks! Chris
ID:	215712   Click image for larger version
chris hart is offline   Reply With Quote
Old 11-24-2015, 09:07 PM   #2
Sherman Oaks , California
Alien eyes?
Hi Chris,
I am working on a 1948 C.W. trailer as well. I'm just starting the Alien windows and was wondering if you ever figured out a gasket for yours?
Andrew in Sherman oaks.
ajcross is offline   Reply With Quote
Old 11-24-2015, 11:57 PM   #3
Hi Andrew. I just made a 1/2" frame out of 1/4" plywood. That is nailed to the skin. That is the original design. I then slathered the wood with Sikaflex and gobbed Sikaflex into the aluminum channel and put it in place. I temporarily screwed it in place to let the Sikaflex dry for a few days. I then put Butyl (not putty) tape (double thickness) around the inside of the frame and bolted the window in place. No leaks. Clean install.
'53 Clipper and '49 Curtis Wright.. Clipper JayDigger Vintage Kin 13 02-24-2015 08:21 AM
Curtis Wright Window install chris hart Vintage Kin 6 07-10-2014 11:54 AM
1949 Curtis Wright Clipper bhayden Vintage Kin 38 01-14-2010 09:16 AM
Curtis-Wright -1936 truckasaurus Airstream Trailer Forums 5 07-05-2005 08:41 AM
