Old 11-02-2013, 06:13 PM   #1
Soyboy's Avatar
1999 28' Excella
Frederick , Maryland
Images: 44
Creation Brand window operator need for '99 Safari
My '99 has Creation brand windows (very similar to Hehrs). Creation went out of business. I need a new window "operator" (the mechanism that the knob attaches to). It is a center mount operator vs. the (from what I understand) the more common side mount. I know that Parkin bought out much of Creation's stock, but they don't list the operator on their website (I am going to give the a long shot call). Has anyone else had any success finding these operators?
Name:	Hehr Operator 99 Safari.jpg
ID:	199172   Click image for larger version
Name:	Hehr Operator 99 Safari Photo 2.jpg
1999 28' Safari
2012 F150 Platinum Max Tow 7650 GVWR 3.73 Elec. Locking Diff.(Prev 2003 Dmax).
Honda EU2000i, Equalizer Hitch
AM Solar Panels 150W - 2 Trojan T 105 6V Batteries
KC3MAP
On internet forums, please research and separate the wheat from the chaff (including mine!)
Soyboy is offline   Reply With Quote
Old 11-02-2013, 06:56 PM   #2
rluhr's Avatar
1968 17' Caravel
2005 30' Safari
Somewhere , roaming America
Some Hehr windows in Airstreams take a center torque operator, part #119-331. This might also fit your Creation windows.
Former full-timer | AIRSTREAM LIFE magazine | Tour of America (old blog) | Man In The Maze (current blog)
rluhr is offline   Reply With Quote
Old 11-02-2013, 07:09 PM   #3
Soyboy's Avatar
1999 28' Excella
Images: 44
Thank's Rich. That looks like it might work with the offset base etc. Might take a flyer on one as it is only $12. Should I count this as subscriber services? lol
Dennie
1999 28' Safari
KC3MAP
Old 11-02-2013, 07:12 PM   #4
Soyboy's Avatar
1999 28' Excella
Images: 44
Here is a pic of the part that Rich mentioned in case you are interested.
1999 28' Safari
KC3MAP
Old 03-29-2014, 02:35 PM   #5
Soyboy's Avatar
1999 28' Excella
Images: 44
Since winter finally relented around here, I thought I would work on changing out the window operator. I drilled and chiseled out the rivets holding it in and then, like the Hehr instructions call for, I tried lifting it up to let the two tubes pop out. Except they wouldn't budge. So I tried sliding the operator sideways and that is when I discovered that the creation windows use a one piece tube with a metal key that fits through a slot in the tube and into the operator, whereas the Hehr windows use two separate tubes that have slots cut into each that then fits into a key built into the operator. The good news is (I think) that slot cut in the Creation tube will (hopefully) match the key in the Hehr operator. But I need to cut 1/4" or so out of the middle of the tube and then see if I can slide it into the slot. Since it's raining today and I need to run an extension cord out to the trailer to run my saw, I packed it in. When I proceed I will come back with another update and hopefully a success story.
1999 28' Safari
KC3MAP
