Old 04-10-2011, 10:23 PM   #1
Fly at Night's Avatar
2010 27' FB Flying Cloud
Fraser Valley , British Columbia
Cost of Replacing Front Window Screen
Well, today was a pretty upetting day. The dog was accidentally locked into the 2010 27' Flying Cloud, and she tore the front bedroom window screen all to hell.
Anyone know the cost of replacing this through the Airstream dealership? Alternatively, is it easy to take the screen out, and have it renetted at a window-screen place; I would imagine that would be cheaper.
Any help/advice would be greatly appreciated.
Fly at Night is offline   Reply With Quote
Old 04-10-2011, 10:34 PM   #2
reinergirl's Avatar
Hollis , New Hampshire
This place does a custom window screen fabrication and has lots of options.
https://www.blainewindow.com/index.cfm
However, if the screen frame is okay its fairly simple to redo the screening and supplies are readily available at your local big box store.
reinergirl is offline   Reply With Quote
Old 04-10-2011, 11:25 PM   #3
The cost of new screening and bead, should be no more than ten bucks, or less.
The screening tool, for the bead, costs more than that.
Old 04-10-2011, 11:36 PM   #4
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
This is an easy fix - probably a do it yourself one. IF you have a "SE" with the bigger windows, the screens are splined into the interior window frame. I wouldn't remove that to fix a screen! I'd just get new screen material with a bit over an inch extra on all four sides, then work the spline back in starting at the top center and working to each side, then around the corners, down the sides, keeping the tension even, then gently toward the center. If you don't have a spline tool (looks like a roller cutter for pizza or fabric, but with a blunt blade, you can actually roll a large coin over the spline to force it back into the channel. Try not to stretch the spline as it will retract and pucker the screen if you do. (If you are absolutely not a do it yourself type, TAKE the RV to the hardware store and ask the screen tech to come out to the parking lot and install the screen.
If yours isn't an SE and has a removable screen frame, then your local hardware store can definitely repair it. NO STRESS, either way it's a cheap, easy fix.
Old 04-11-2011, 05:38 AM   #5
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
I would try a DIY first. If that doesn't work out for you, try your local hardware store, many of them offer rescreening and glass cutting. Having an Airstream dealer do it would probably be cost prohibitive. Figure an hour's labor plus fuel and time getting it to and from the dealer.
Old 04-11-2011, 05:42 AM   #6
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
There are different sizes of beads. I'd take a piece of the bead with you so that you can get the same size.
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 04-11-2011, 08:03 AM   #7
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
Lowes or Home Depot will make it like new.
Ahab is offline   Reply With Quote
Old 04-11-2011, 01:39 PM   #8
Thanks all for your replies.
I don't have the time or patience to try to fix myself. I will contact Home Depot and see what they say. I could tow the trailer there, I guess.
Old 06-27-2011, 08:10 AM   #9
1968 26' Overlander
1976 31' Sovereign
Seattle , Washington
n/m
found the answer in another thread!
tonka71 is offline   Reply With Quote
Old 08-17-2011, 10:45 AM   #10
Update: the dealership did it for $90 when the unit was in for warranty work. I was okay with that - just wanted to get it done.
Thanks all, for your help/suggestions.
AS280 - Front (driver) sliding window latch dalefox Classic Motorhomes 14 09-13-2018 08:05 PM
Replace missing front window with jalousie? Cruisette Windows & Screens 6 03-31-2011 04:23 PM
2007 Classic front center window glass/frame interference dznf0g 2006 - 2010 Classic (all lengths) 0 03-23-2011 09:44 AM
Front window leak fix? BarnacleBill Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 7 01-18-2011 05:04 PM
